Volume channel noise?
Is there anyway to prevent the noise that is created when you poke the volume chanel.
Re: Volume channel noise?
Yes, the pop is bigger the bigger the difference in volume change. So you can do it gradually.
Compare this:
10 FORT=0TO15:POKE36878,T:NEXT
20 FORT=15TO0STEP-1:POKE36878,T:NEXT
30 GOTO10
to this:
10 POKE36878,15:POKE36878,0:GOTO10
Compare this:
30 GOTO10
to this:
Is there anyway te prevent it when modulating it dramatically?Boray wrote:Yes, the pop is bigger the bigger the difference in volume change. So you can do it gradually.
Compare this:
30 GOTO10
to this:
Even when modulating byou a value of 1 there's a light buzz.
Well, you could always turn the volume down on your monitor...
I want to write a synth program. I would like to use mudulation on the volume channel for attack, delay and effects. I would also like to use it for recording and maybe live performance. I thought I saw a post on how to avoid the volume channel noise a while back but I can't seem to find it now.Boray wrote:Well, you could always turn the volume down on your monitor...
- pixel
- Website: http://hugbox.org/
One could write a real-time mixer to play rectangular waveforms via the volume register, perhaps running as a self–modifying NMI routine on the zero page to push up the maximum sample rate. Had something like that but it got lost somewhere on Github. The bass was epic. Make the waveforms fill a 256-byte page each and you should get the algorithm rocking, soon.R'zo wrote:I want to write a synth program. I would like to use mudulation on the volume channel for attack, delay and effects. I would also like to use it for recording and maybe live performance. I thought I saw a post on how to avoid the volume channel noise a while back but I can't seem to find it now.
- pixel
Here's a little inspiration.
; !!!! QUICK OFFICE BREAK SKETCH !!!! of a 4 channel 4-bit audio sample player.
; No special zero page hacks.
sample_rate = 8000
cpu_cycles_pal = 1108404
timer = cpu_cycles_pal / sample_rate ; PAL
.data
; Positions in waveform is 16bit but only the high byte is used as a pointer into a 256 byte wave forms.
; That way one gets a 16bit resolution for the frequency!
waveform_position_a: .word 0
waveform_position_b: .word 0
waveform_position_c: .word 0
waveform_position_d: .word 0
waveform_freq_a: .word 0
waveform_freq_b: .word 0
waveform_freq_c: .word 0
waveform_freq_d: .word 0
.code
main:
jsr disable_nmi_and_other_interrupts
jsr boost_digital_audio
jsr start_player
jmp to_the_application
start_player:
jsr enable_nmi
; Set NMI frequency and start timer.
lda #<timer
sta $9114
lda #>timer
sta $9115
; Set NMI vector.
lda #<play_audio_sample
sta $318
lda #>play_audio_sample
sta $319
cli ; Tell CPU to take interrupts.
rts
play_audio_sample:
pha
txa
pha
; Restart the NMI timer (only setting high byte required).
lda #>timer
sta $9115
; Add all current 4-bit(!) samples together.
clc
ldx waveform_position_a+1
lda waveform_a,x
ldx waveform_position_b+1
adc waveform_b,x
ldx waveform_position_c+1
adc waveform_c,x
ldx waveform_position_d+1
adc waveform_d,x
; Divide by 4.
lsr
lsr
lsr
lsr
; Play sample via volume register.
sta $900e
; Step to next sample of channel A.
lda waveform_position_a
clc
adc waveform_freq_a
sta waveform_position_a
lda waveform_position_a+1
adc waveform_freq_a+1
sta waveform_position_a+1
; Step to next sample of channel B.
lda waveform_position_b
clc
adc waveform_freq_b
sta waveform_position_b
lda waveform_position_b+1
adc waveform_freq_b+1
sta waveform_position_b+1
; Step to next sample of channel C.
lda waveform_position_c
clc
adc waveform_freq_c
sta waveform_position_c
lda waveform_position_c+1
adc waveform_freq_c+1
sta waveform_position_c+1
; Step to next sample of channel D.
lda waveform_position_d
clc
adc waveform_freq_d
sta waveform_position_d
lda waveform_position_d+1
adc waveform_freq_d+1
sta waveform_position_d+1
; Return from NMI.
pla
tax
pla
rti
boost_digital_audio:
lda #$fe ; (Highest frequency on soprano channel.)
ldx #$7e ; (Channel off.)
stx $900c ; Stop soprano channel.
ldy #0 ; Wait a couple of cycles.
l: dey
bne l
; Give soprano a beating.
stx $900c ; off
stx $900c ; off
sta $900c ; on
sta $900c ; on
stx $900c ; off
sta $900c ; on
rts
enable_nmi:
lda #$40
sta $911b
lda #$c0
sta $911e
rts
disable_nmi_and_other_interrupts:
sei
lda #$7f
sta $911e
sta $912e ; Perhaps these two could be left out.
sta $912d
rts
pixel wrote:Here's a little inspiration.
; !!!! QUICK OFFICE BREAK SKETCH !!!! of a 4 channel 4-bit audio sample player. [/quote] Thank you pixel. It will take me some time to look this over. I usually have a hard time understanding code written by others but most of this actually makes sense to me :)
