10-Bit Oscillator Frequency Resolution
aeb
Post by aeb »
One of the most annoying things about VIC 20 is that the music all too often plays horribly out of tune. This program improves the frequency accuracy of square voices 1-3 from 7 bits (0-127) to 10 bits (0-1023).
Fantastic! :D
Download: http://www.cncd.fi/aeeben/download/10-bit-ofr.zip
To init: jsr $0340 or sys832
To stop: lda #$40, sta $911e or poke37150,64
Set VIA #1 timer 1 rate ($9114/$9115) to adjust sound quality. Default is $0580.
Set sound quality in basic: poke37141,x (x=5 default, x=0 highest, usable low quality range up to x=30)
Default value is usually quite fine unless you play very high notes.
$f8/248 Voice 1 enable (bit 7) & frequency high 7 bits (bits 6-0) (same as $900a/36874)
$f9/249 Voice 2 -"- (same as $900b/36875)
$fa/250 Voice 3 -"- (same as $900c/36876)
$fb/251 Voice 1 frequency low 3 bits (range 0-7)
$fc/252 Voice 2 -"-
$fd/253 Voice 3 -"-
Invalid values (>7) in $fb-$fd will cause inaccurate sound output.
The note and Hz values in frequency tables pal-freqtable.png and ntsc-freqtable.png are calculated for Voice 1, the lowest voice.
Voice 2 plays an octave higher (Hz * 2)
Voice 3 plays two octaves higher (Hz * 4)
pal-freqtable.bin / ntsc-freqtable.bin format:
The first 72 ($48) bytes are high bytes for writing to $f8-$fa
The next 72 bytes are low 3 bit values for $fb-$fd
LOAD"10-BIT-OFR.PRG",8,1
SEARCHING FOR 10-BIT-OFR.PRG
LOADING
READY.
NEW
READY.
SYS832:POKE36878,15:REM Init and set volume
POKE248,215:POKE251,5:REM Play A-1 / 110Hz on ch 1 (36874)
POKE249,215:POKE252,5:REM Play A-2 / 220Hz on ch 2 (36875)
POKE250,215:POKE253,5:REM Play A-3 / 440Hz on ch 3 (36876)
POKE248,0:POKE249,0:POKE250,0:REM Stop all voices
POKE36877,130:REM You can use noise channel normally
POKE37141,0 - Set highest quality (great for high notes, but slows down basic)
POKE37141,5 - Set default quality (good quality/cpu load balance)
POKE37150,64 - Disable timer NMI, sys832 to start again
Basic Loader:
1 fora=832to915:readb:pokea,b:next
100 data169,99,141,24,3,169,3,141,25,3,169,128,141,20,145,133,254,162,5,142,21,145,169
101 data0,149,248,202,16,251,169,192,141,30,145,96,72,152,72,138,72,6,254,144,2,230,254
102 data162,2,180,251,185,140,3,180,248,37,254,240,1,200,152,157,10,144,202,16,237,104
103 data170,104,168,104,44,20,145,64,0,128,136,146,170,218,238,254
Frequency Tables:
Website: http://hugbox.org/
Re: 10-Bit Oscillator Frequency Resolution
aeb wrote: Fantastic! :D
Absolutely! And genius!
Am wondering what games will look like in 2020! :D
tlr
Post by tlr »
Interesting approach. Special +1 for posting source code. Haven't tried it on hw, how good quality can you get?
Post by R'zo »
I can't wait to find the time to rest it out.
armypavarmy
Post by armypavarmy »
Hello .
I tried to adapt the song “sonata c major”
with 10bit program.
I like writing basic music with the Vic20.
Unpacked the .zip file for
play with winvice or true vic20 and drive or Sd2iec
Armando .
10bit-sonata.zip
(1.95 KiB) Downloaded 335 times
aeb
Post by aeb »
You're using it wrong... Your program only sets the high 7 bits of frequency, so there's no difference from normal VIC frequency resolution.
You need to include also the low 3 bits in the data for each note - the small values 0-7 in the frequency table at start of this thread - and write them to the other zero page register. Now you're writing the same 8-bit value to both registers, on line 230, which doesn't make any sense.
- Registers S2,S3 defined in 130 should be 248,251 or 249,252 or 250,253 depending on the voice you want to use
- Line 210: READP,L,D
- 230 POKES2,P:POKES3,L
- Edit all data statements on lines 300-1730 and add the low 3 bits (0-7) for each note
300 DATA 225,8,231,4,235,4,... =>
300 DATA 225,4,8,231,5,4,235,3,4,... etc
:shock: :)
armypavarmy wrote:Hello .
with 10bit program.
Armando .
10bit-sonata.zip
armypavarmy
10 bit test
Hello
please check this music
that I wrote to try
your corrections.
and tell me if it's okay.
For the songs already written I have to
change the value of the note too
that in your table is different.
from those used in 8-bit for Pal
thanks greetings Armando
10bit-pr.prg.zip
(655 Bytes) Downloaded 347 times
aeb
Post by aeb »
Very nice! :D
armypavarmy wrote:10 bit test
Hello
that I wrote to try
your corrections.
10bit-pr.prg.zip
How does this work exactly? I.e. the theory behind it as opposed to how to use it...
armypavarmy
Hello
composed song using
the 10bit oscillator program
new simple Christmas song
Best wishes to all.
Armando
10bit-christmas.prg.zip
(1022 Bytes) Downloaded 332 times
armypavarmy
Hello
composed a new song using
Name “ Let Is Snow “
let is snow-10bit.prg.zip
(1.31 KiB) Downloaded 339 times
Kweepa
Occupation: Game maker
Post by Kweepa »
It toggles between the high byte and the high byte + 1, depending on the low byte.
The data table determines when to add 1 to the high byte, on an eight bit cycle.
EDIT Ah, I didn't notice there was already source code in the ZIP! :)
rolledbit $FE
freq $F8 ; one byte per channel
mod $FB ; one byte per channel
VIA_NMIENABLE $80
VIA_T1ENABLE $40
VIA1_CTRLBYTE $911E
.C:0340  A9 63       LDA #>interrupt ; install interrupt handler
.C:0342  8D 18 03    STA $0318
.C:0345  A9 03       LDA #<interrupt
.C:0347  8D 19 03    STA $0319
.C:034a  A9 80       LDA #$80        ; set T1 freq to $580
.C:034c  8D 14 91    STA timer1low
.C:034f  85 FE       STA rolledbit
.C:0351  A2 05       LDX #$05
.C:0353  8E 15 91    STX timer1hi
.C:0356  A9 00       LDA #$00        ; turn off all channels
.C:0358  95 F8       STA freq,X
.C:035a  CA          DEX
.C:035b  10 FB       BPL -
.C:035d  A9 C0       LDA #(VIA_NMIENABLE+VIA_T1ENABLE)
.C:035f  8D 1E 91    STA VIA1_CTRLBYTE
.C:0362  60          RTS
interrupt:
.C:0363  48          PHA
.C:0364  98          TYA
.C:0365  48          PHA
.C:0366  8A          TXA
.C:0367  48          PHA
.C:0368  06 FE       ASL rolledbit ; roll a bit around a byte
.C:036a  90 02       BCC +
.C:036c  E6 FE       INC rolledbit
.C:036e  A2 02       LDX #$02 ; loop over channels
loop:
.C:0370  B4 FB       LDY mod,X
.C:0372  B9 8C 03    LDA datatable,Y
.C:0375  B4 F8       LDY freq,X
.C:0377  25 FE       AND rolledbit ; check if rolled bit is set
.C:0379  F0 01       BEQ +
.C:037b  C8          INY
.C:037c  98          TYA
.C:037d  9D 0A 90    STA $900A,X ; set channel freq
.C:0380  CA          DEX
.C:0381  10 ED       BPL loop
.C:0383  68          PLA
.C:0384  AA          TAX
.C:0385  68          PLA
.C:0386  A8          TAY
.C:0387  68          PLA
.C:0388  2C 14 91    BIT $9114
.C:038b  40          RTI
datatable:
.C:038c  %0, %10000000, %10001000, %10010010, %10101010, %11011010, %11101110, %11111110
armypavarmy
Hello
two new music
rewritten by me at 10Bit.
Sonata in D major
Turkish march
Armando
10bson.zip
(2.12 KiB) Downloaded 335 times
mt10sc.zip
(2.71 KiB) Downloaded 330 times
armypavarmy
Hello
one new music
Somethin’ Stupid
Armando
10bstup.zip
(1.22 KiB) Downloaded 333 times
armypavarmy
Two new songs
10bit piano Vic 20two new songs
the first of Anonymous
the second traditional Irish song
Armando
10blrpg.zip
(1.08 KiB) Downloaded 376 times
