Bitmap graphics demos/slideshows (by Miklós)
- Occupation: butcher
Hi all.
Magic Fractal v1.1
I'm sorry, no music.
Magic Fractal v1.1
- MKS DEMO.ZIP
- (55.61 KiB) Downloaded 121 times
- mfraktal.PNG (6.25 KiB) Viewed 2662 times
Re: Bitmap graphics demos/slideshows (by Miklós)
Hi all
Picture conversion
unexpanded VIC
Dropout update.
I apologize for the noise in the previous picture.
Unfortunately, I did not test for sound.
Picture conversion
unexpanded VIC
Dropout update.
- DO+PIC.ZIP
- (8.92 KiB) Downloaded 103 times
- tetpic2.PNG (4.72 KiB) Viewed 2631 times
Hi all
5 picture 1 file 16k
original source file:
http://www.zimmers.net/anonftp/pub/cbm/ ... index.html
-NTSC center
-BITMAPP bit pair swap
-NEW COLOR SETUP
-MEM SWAPPER
-SELF-MODIFYING CODE
-NTSC center
-NEW COLOR SETUP
-MEM SWAPPER
- old pic new set.zip
- (358.43 KiB) Downloaded 100 times
Hi, Miklós,
I moved your recent postings in the thread "Welcome! Please add your programs." to an own thread.
What set of tools do you use to build these pictures? Is this a manual or at least somewhat automated process? Is there a way to use them in own programs? It would be nice for example, if one could instruct the own program to show such a picture on screen, wait for a key press, restore text mode and then continue with the own program.
I am mostly asking because these were some of the reasons that once motivated me to write MINIGRAFIK and its assorted set of tools. On the disk, if you take a look at the included slide shows, you might recognize one of the pictures you took as example.
Good day.
Thu VS Thu
Comparison of two images.
-I took the frame off my conversion.
-8x16 char ---> c64bitmap
-remake on artstudio and convert -> 8x16pixel / 22 char / row
The music is also a demo version, I did it with my editing program. And the player is its own.
- I didn't take it seriously, I laugh at it too.
Live bitmap 1.1
-I had a good time and I'm looking for opportunities.
-Frame eliminated, another bitmap conversion.
8x16 -> 8x8 Charset
Lake 1.1
-It drew this picture.
--C64 Art studio 1.2b
23/18 character 8x8 pixels / char
Thu VS Thu
Live bitmap 1.1
8x16 -> 8x8 Charset
Lake 1.1
- MKS.ZIP
- (37.51 KiB) Downloaded 106 times
- BMD.PNG (4.27 KiB) Viewed 2470 times
Good day.
Jetpac pic (p)
Sorry this is running on a PAL machine due to 32 char / line.
- This is the original aspect ratio.
-Vice 3.2 emulator: Settings / VIC settings / Debug border
setting is the most beautiful.
Jetpac pic (p)
Jetpac picture NTSC / PAL
It has long been concerned with how to do it on an NTSC machine as well
this oversized image.
By setting the VICE emulator 3.2, I really like the PAL image.
PAL 32 characters wide.
Thus, the NTSC image is 31 characters wide.
(a little game: where's the difference?)
22.sept. V3 8k
Re-coded image. Aspect ratio retained.
I designed it for real hardware and a tv or monitor.
22.sept. V3 8k
- MKS JETPAC PIC V3.ZIP
- (9.54 KiB) Downloaded 103 times
- JP.zip
- (12.71 KiB) Downloaded 101 times
Good morning.
My latest development:
VIC20 rayracing 16k PAL / NTSC
- raytraceing.zip
- (6.78 KiB) Downloaded 101 times
Hi, Miklós,
this is nice application for flipping multiple bitmaps. Two points to note though:
- Most of the time, the 'spheres' don't keep their rotation sense and merely seem to wiggle left/right, which is somewhat irritating. Sometimes, after a colour change, it works.
- Speaking of 'spheres': you did a 1:1 pixel translation from C64 multi-colour bitmap to VIC-20. That inevitably changed the round spheres to flat ellipoids. It would be a big improvement, if you'd take the different pixel aspect ratios into account. An even better option would be recalculating the raytracing scene and its animation phases with the correct pixel size and screen dimensions to suit the VIC-20.
Very Nice. Well done Miklos.Miklós wrote: ↑Thu Jul 01, 2021 2:08 am Jetpac picture NTSC / PAL
Column one is the difference
Hi all.
Hi-res picture 8k.
Hi-res picture 8k.
- cg hires.zip
- (2.96 KiB) Downloaded 94 times
Hi ALL
ALF PIC 8k
image conversion with the new MKS KOALA PIC ADJUSTOR (test)
ALF PIC 8k
- aug 11 update.zip
- (270.61 KiB) Downloaded 97 times
- VIC ALF.PNG (8.01 KiB) Viewed 2158 times
- VIC RAYTRACEING V2.zip
- (6.75 KiB) Downloaded 104 times
- RT.PNG (7.14 KiB) Viewed 2132 times
