VicSAM without SID
VicSAM without SID
Hi
VicSAM without SID (Software Automatic Mouth).
I state that this program dates back to about 10 years ago.
I found it and recovered it from a broken hard drive of mine.
The goal was to make it work without the SID.
I remember that I did other tests and wrote other releases but
then for serious health problems in the family I abandoned everything.
At the time I no longer had a working Vic20, it only ran with
winvice emulator, now I would be curious if it works on a real Vic20
with all memory banks (blk1, blk2, blk3 and blk5).
With the Winvice emulator it works discreetly.
The commands should be the same as in SAM for the C64.
In addition there is the command ]LI0 and ]LI1 and actually I don't remember
anymore the operating logic (to reduce noise).
I don't know if there is anything like this just software on the Vic20.
From the research I have done it seems not, but I can be wrong.
Old memories:
In the 80s I was fascinated by the SAM of the C64 and mine
Vic20 pumped managed to mount the SID in parallel to the rom with
a TTL logic circuit that allowed reading from the ROM e
to write in the SID by acting on pins R/W and CS.
At the time I did some experiments with SAM and it worked.
I thank you for your welcome and greet you.
Raros
(Sorry for the bad English. Google translator)
Old memories:
Raros
- vicsam7.zip
- VicSam vers.7
- (15.45 KiB) Downloaded 111 times
Re: VicSAM without SID
Hi
I was able to recover this source in ASM as well.
It is not the latest version. I'm sorry for the lines of comments that are in Italian.
Raros
Raros
- VICSAM2_RUN_7CA0_new.zip
- (34.21 KiB) Downloaded 81 times
Hi, Raros,
first of all, welcome to Denial!
It is really nice to see (or better say, hear) a port of SAM for the VIC-20. In those times, I extensively used SAM in the C64 mode of my C128, both in phoneme mode and reciter mode. Hopefully I'll come to test it on my VIC-20 this weekend.
There exist some hardware based solutions (cartridge and userport), and a coder from Argentina put out a pure software speech synthesizer (TAV20) quite recently, so the VIC-20 got two of those within short time!Raros wrote:I don't know if there is anything like this just software on the Vic20.
Thanks Mike for the welcome.
This "tav20" is interesting to try.
Raros
Raros
Hi Raros!
Welcome to the forum!
Here's the program running on my Vic-20, so you can hear that it works perfectly also on a real machine
https://www.dropbox.com/s/3t29w5wqu89mg ... 5.mp4?dl=0
Ciao!
Enrico
Ciao!
Enrico
Wow fantastic . Thank you.
Ciao, Enrico
E l'Ave Maria di Gounod si sente decentemente?
And does Gounod's Ave Maria feel decently?
Raros
Ciao, Enrico
Raros
- mathom
This is quite amazing to me. I am constantly astonished with what our little, old VICs are capable of.
...mathom...
Hi
Dedicated to Italian friends.
In the 80s-90s the Italian 'System editoriale' published 'La Voce 3' for C64, basically a SAM in Italian.
I am also able to recover my port on Vic20 always without SID.
The difference between C64 and Vic20 are the '[' and ']' commands. In the C64 they turn the video off and on,
while on Vic20 they act on the cleaning of the voice.
I added 'Vic Song' originally written for the C64.
The manual I am attaching I have downloaded from the ready64.org site which I thank.
Listing of 'Voice6.Boot.Bas':
Listing of 'vic song':
Raros
10 REM LA VOCE DEL VIC 4
13 REM VOX "]" = HIFI! AUDIO CON VOLUME BASSO (DEF)
15 REM VOX "[" = GROWL AUDIO CON VOLUME ALTO
16 REM
18 PRINT"“":PRINT CHR$(158):PRINT:POKE 36879,110
20 PRINT" LA VOCE3 DEL ";CHR$(05)"VIC":PRINTCHR$(159)
30 PRINT" B Y":PRINT CHR$(144)
40 PRINT" R A R O S":PRINT:PRINT CHR$(159):PRINT
50 IF LF=0 THEN LF=1:GOTO 100
60 IF LF=1 THEN LF=2:GOTO 110
80 SYS 24960:CLR
81 VOX "[SONO PRONTO8"
82 VOX "]"
83 NEW
100 LOAD "VOCE6.A000.VIC*",8,1
110 LOAD "VOCE4.6180.VIC*",8,1
666 REM
5 vox "[":rem Bisognerebbe cambiarla in ']'
10 play 21,20
20 vox "brill"
30 play 17,140
40 vox "laan"
50 play 21,150
60 vox "coooooooooor"
65 vox " "
70 play 19,160
80 vox "caal"
90 play 17,199
100 vox "do"
110 play 19,160
120 vox "spleen"
130 play 21,140
140 vox "di"
150 play 17,150
160 vox "dool"
170 play 14,150
180 vox "soooo"
190 play 9,140
200 vox "leeeeee"
210 vox "]"
- VicVoce3 ITA.zip
- VicVoce3 In Italiano
- (9.26 KiB) Downloaded 85 times
- ManualeVoce3.zip
- Manuale Voce3 per il C64
- (83.09 KiB) Downloaded 78 times
What can I say in English? Nothing but Italian words of surprise come to mind (incredibile! pazzesco! se non l'avessi sentito con le mie orecchie, non ci avrei creduto!). And one more: GRAZIE for this precious jewel.
I can't wait to surprise friends - and have fun with my daughter, much in the same way we made the Commodore 64 swear like a dock worker
- Vic 20 Devotee
- Website: http://davbucci.chez-alice.fr
Quite impressive! Great work!
Other three quick tests so you can hear that everything works on a real Vic-20
(sorry for the presence of some noise, otherwise I would have to wait at least another day)
VicVoice3: to a friend...
https://www.dropbox.com/s/j4vtnd3ttbhjo ... 0.mp4?dl=0
VicSam: some other speech
https://www.dropbox.com/s/2mda63sq9m5ah ... 0.mp4?dl=0
VicSam: Ave Maria
https://www.dropbox.com/s/obkyc91wagu63 ... 0.mp4?dl=0
great work Raros!
VicSam: Ave Maria
great work Raros!
P.S. and I tell you that I had the original of "La Voce 3" for the C64, back in the day! So cool and so much fun!
Thanks thanks thanks
However it feels really good on a real VIC20.
I'm happy too
Raros
- Vic 20 Hobbyist
Good program , but
If load and run program "vic song"
bad voice and at the end
Message " ? sintax error in line 8280 "
With emulator WinVice 3.1 or Vic20 real
Thank you for help. Armando
