Bitmap printer output in VICE
Can someone give me the correct command line to get a BMP file of the printer output? I've tried
$ xvic -memory none -iecdevice4 -device4 1 -pr4drv mps803 -pr4output graphics -pr4txtdev 0 -prtxtdev1 /tmp/output
but no file is written. I'm sure I had this working with an older version of VICE, currently running 3.4.
mathom
Occupation: Software Engineer
Re: Bitmap printer output in VICE
Post by mathom »
This could be your problem:
https://sourceforge.net/p/vice-emu/bugs/1281/
You might want to check it out and add any new info. The devs are starting a push to do the next release by the end of the year.
...mathom...
...mathom...
did you trigger a formfeed and/or close the emulator? else no output is produced.
groepaz wrote: Sun Oct 18, 2020 11:43 am did you trigger a formfeed and/or close the emulator? else no output is produced.
Closed VICE, no file is created.
I am investigating this ... apparently "iecdevice" actually never worked with xvic. Try to enable virtual device traps (-virtualdev), that should make it work (please confirm).
That seems to work, I get the following output from VICE
Serial Interface: Error - Flush printer #4,0 while closed - ignoring.
Serial Interface: Auto-opening printer #4,0.
and a bitmap file created.
I did get the following when I quit VICE
Exiting...
Sound: Closing device `pulse'
corrupted double-linked list
Aborted (core dumped)
I'll see if it's reproducible.
Seems reproducible
Exiting...
[Thread 0x7fffe5a37700 (LWP 10352) exited]
Thread 1 "xvic" received signal SIGABRT, Aborted.
0x00007ffff6b13a7a in raise () from /lib64/libc.so.6
(gdb) where
#0  0x00007ffff6b13a7a in raise () at /lib64/libc.so.6
#1  0x00007ffff6afc524 in abort () at /lib64/libc.so.6
#2  0x00007ffff6b55ff8 in  () at /lib64/libc.so.6
#3  0x00007ffff6b5c89a in  () at /lib64/libc.so.6
#4  0x00007ffff6b5cc4c in unlink_chunk.isra () at /lib64/libc.so.6
#5  0x00007ffff6b5dc0d in malloc_consolidate () at /lib64/libc.so.6
#6  0x00007ffff6b5e400 in _int_free () at /lib64/libc.so.6
#7  0x000000000046f98b in drivecpu_shutdown ()
#8  0x000000000046e545 in drive_shutdown ()
#9  0x0000000000428a9a in machine_shutdown ()
#10 0x00007ffff6b15ecc in __run_exit_handlers () at /lib64/libc.so.6
#11 0x00007ffff6b15ffa in  () at /lib64/libc.so.6
#12 0x00000000004376d9 in  ()
#13 0x00000000004ffaaa in ui_exit ()
#14 0x0000000000500f55 in ui_main_window_delete_event ()
#15 0x00007ffff79b63e4 in _gtk_marshal_BOOLEAN__BOXEDv () at /lib64/libgtk-3.so.0
#16 0x00007ffff711ffc6 in _g_closure_invoke_va () at /lib64/libgobject-2.0.so.0
#17 0x00007ffff713b66d in g_signal_emit_valist () at /lib64/libgobject-2.0.so.0
#18 0x00007ffff713c1b2 in g_signal_emit () at /lib64/libgobject-2.0.so.0
#19 0x00007ffff79654e4 in gtk_widget_event_internal () at /lib64/libgtk-3.so.0
#20 0x00007ffff7830f3b in gtk_main_do_event () at /lib64/libgtk-3.so.0
#21 0x00007ffff75402d5 in _gdk_event_emit () at /lib64/libgdk-3.so.0
#22 0x00007ffff75700d2 in gdk_event_source_dispatch () at /lib64/libgdk-3.so.0
#23 0x00007ffff7038665 in g_main_context_dispatch () at /lib64/libglib-2.0.so.0
#24 0x00007ffff70389e8 in g_main_context_iterate.isra () at /lib64/libglib-2.0.so.0
#25 0x00007ffff7038a6c in g_main_context_iteration () at /lib64/libglib-2.0.so.0
#26 0x00000000004ff7e1 in ui_dispatch_events ()
#27 0x000000000050988a in vsyncarch_postsync ()
#28 0x0000000000434d65 in vsync_do_vsync ()
#29 0x0000000000454e22 in vic_raster_draw_handler ()
#30 0x0000000000453a93 in vic_cycle ()
#31 0x0000000000446431 in maincpu_mainloop ()
#32 0x000000000042902b in main_program ()
#33 0x00007ffff6afdb0b in __libc_start_main () at /lib64/libc.so.6
#34 0x0000000000415c5a in _start ()
(gdb)
I'll run it through valgrind.
[edit]
Looks like there's some problems in the printer shutdown code
==13616== Invalid read of size 1
==13616==    at 0x4C63F2: output_graphics_line_data (output-graphics.c:96)
==13616==    by 0x4BE5D7: bmpdrv_write (bmpdrv.c:223)
==13616==    by 0x4C6645: UnknownInlinedFun (output-graphics.c:177)
==13616==    by 0x4C6645: output_graphics_close (output-graphics.c:167)
==13616==    by 0x4C5B43: close_pr (interface-serial.c:267)
==13616==    by 0x4C5BEF: interface_serial_detach (interface-serial.c:496)
==13616==    by 0x4C603A: interface_serial_shutdown (interface-serial.c:519)
==13616==    by 0x428A58: machine_shutdown (machine.c:294)
==13616==    by 0x5BAEECB: __run_exit_handlers (in /usr/lib64/libc-2.29.so)
==13616==    by 0x5BAEFF9: exit (in /usr/lib64/libc-2.29.so)
==13616==    by 0x4376D8: archdep_vice_exit (archdep_atexit.c:119)
==13616==    by 0x4FFAA9: ui_exit (ui.c:1890)
==13616==    by 0x500F54: ui_main_window_delete_event (uicommands.c:225)
==13616==  Address 0x6f7f5a0 is 0 bytes inside a block of size 480 free'd
==13616==    at 0x4835900: free (vg_replace_malloc.c:540)
==13616==    by 0x4C68E1: output_graphics_shutdown (output-graphics.c:270)
==13616==    by 0x4BFFB8: printer_shutdown (printer.c:113)
==13616==    by 0x4EE43E3: ??? (in /usr/lib64/libgtk-3.so.0.2404.4)
==13616==    by 0x56BFFC5: ??? (in /usr/lib64/libgobject-2.0.so.0.6000.2)
==13616==    by 0x56DB66C: g_signal_emit_valist (in /usr/lib64/libgobject-2.0.so.0.6000.2)
==13616==  Block was alloc'd at
==13616==    at 0x4834753: malloc (vg_replace_malloc.c:309)
==13616==    by 0x42704D: lib_malloc (lib.c:571)
==13616==    by 0x4C6545: output_graphics_open (output-graphics.c:155)
==13616==    by 0x4C2074: UnknownInlinedFun (drv-mps803.c:437)
==13616==    by 0x4C2074: drv_mps803_open (drv-mps803.c:414)
==13616==    by 0x4C5E04: open_pr.isra.3 (interface-serial.c:202)
==13616==    by 0x4C5ECE: write_pr (interface-serial.c:246)
==13616==    by 0x4D5AD3: fsdrive_write (fsdrive.c:257)
==13616==    by 0x4D502E: serial_trap_send (serial-trap.c:179)
==13616==    by 0x433696: traps_handler (traps.c:253)
==13616==    by 0x44B6C4: maincpu_mainloop (6510dtvcore.c:1729)
==13616==    by 0x42902A: main_program (main.c:286)
==13616==    by 0x5B96B0A: (below main) (in /usr/lib64/libc-2.29.so)
so what *exactly* did you do? :)
edit: nvm, i can reproduce it
edit++: thehell, and now i cant anymore. please tell! and please provice a commandline starting with -default :)
VICE built with --enable-native-gtk3ui --with-pulse --enable-cpuhistory, run with
xvic -memory none -virtualdev -iecdevice4 -device4 1 -pr4drv mps803 -pr4output graphics -pr4txtdev 0 -prtxtdev1 test_output
Enter the following program
10OPEN4,4
20PRINT#4,"TESTING"
30CLOSE4
then quit VICE, poof.
thats not enough to reproduce it reliably... for some reason it worked (as in crashed) exactly once for me, subsequent tests work fine (no crash). thats why i asked for a commandline starting with -default :) and please test it a few times (preferably by autostarting your little test program, so i dont have to type it all the time)
made a ticket about it for the time being: https://sourceforge.net/p/vice-emu/bugs/1336/
-autostart and -autoload affect the reproducibility for me too, it only happens when I type the program in.
try the next nightly build, it should be fixed in r38886
I created a patch with the fix from svn, it now doesn't crash.
sounds good :)
