message "division by zero error"
- Vic 20 Hobbyist
good morning. I am Armando
please help.
Data entered for calculation
parameters for graphics
give this error.
The parameters are right.
in fact, by restarting the run at the second insertion they work
This happens every time you enter the required data, you have to run and re-enter them.
There is a solution to this problem.
Thanks for help ....
please help.
give this error.
- Occupation: farmer
Re: message "division by zero error"
Hello Armando,
Can you make that program available to us ?
Regards,
Wim.
Regards,
Wim.
- Vic 20 Hobbyist
sure ..... I prepare the material and then insert ......
Thanks-------Armando
- Vic 20 Hobbyist
Hello
here is the zip file it contains
the graphic program for "Super Expander"
and the link from which I downloaded.
It has pre-entered parameters if you hit return
without any number.
Even with these you have to repeat the run.
Tested with emulator and with real Vic20
Same problem.
Thanks .......... Armando
without any number.
Same problem.
If I run this and just hit RETURN at every prompt, I get a five-pointed cloverleaf-like pattern. (Real VIC-20 with Super Expander)
Armando.
What memory configuration are you using ? Line 260 is assuming you have 3.5k or maybe 6.5k, but not +8k or +16k.
What I think happens is that the POKEs in line 260 overwrite the memory space for simple variables, and subsequently Z cannot be found anymore, resulting in Z=0. In line 270 a A(P)=1/Z is performed, resulting in ?DIVISION BY ZERO.
Regards,
Wim.
Regards,
Wim.
- Vic 20 Hobbyist
Hello
Loading the "super expander" program with the FE3 automatically configures all the ram.
I can't make any other choice.
If possible, how to change the program?
Thanks regards Armando
change line 260 to
260 FOR I=4536 TO 4579 : POKE I,32 : NEXT I
- Vic 20 Hobbyist
Hello
Made modification indicated.
Same problem.
Saved modified program, I reset everything and reloaded.
Like before. same mistake
......Armando
Same problem.
......Armando
- Vic 20 Hobbyist
I'll wait for an answer
because the proposed solution does not work. thanks ..... Armando
If you select 1 at the 'how many spirals' prompt, you may enter your own parameters into the following prompts.
If you select 2-4 at the first prompt, you have to keep pressing return at every other prompt until the second prompt (spriral figure #) equals the number you chose at the first prompt, then you can enter your own parameters into the following prompts.
I think this is just how the program works.
viewtopic.php?t=5396&start=59, and to quote from there:
I should add, that this issue does not occur with MINIGRAFIK at all: there, the graphics area is already created with the initialisation of MG and stays put as long as MG is active.
It is surely instructive to port the "Spiralizer" program to MINIGRAFIK.
Emphasis added. That's what happens here (Armando, I take it here you soft-load SE with a full RAM expansion in VICE), which ultimately leads to the ?DIVISION BY ZERO error: the program switches between deactivated/removed graphics area in lines 100..410, and when in line 420 the command GRAPHIC 2 creates the graphics area *and* a bigger RAM expansion is present, all variables are cleared. A better way would be to create the graphics area once, right at the begin, and just change between text and graphics mode with GRAPHIC 0 and GRAPHIC 2, respectively.Mike wrote:just for general info: when a graphics screen is activated the first time, SE normally 'lowers the roof' available for the BASIC program and variables down to $0FFF (minus some extra for function key definitions). With +8K RAM or more, the BASIC start is set to $2001 instead, and the program is copied to the higher address, clearing all variables underway.
- Vic 20 Hobbyist
Hello Mike
thanks so much for your unexpected help.
Now the program works.
It's very beautiful.
I would like to bring it to Minigrafik
The problem is that Minigrafik
does not have the command: Draw TO X, Y.
Whenever possible I always adapt graphic programs
with Minigrafik.
greetings ----- Armando
with Minigrafik.
Hi, Armando,
This is done in MINIGRAFIK with two temporary variables XC,YC that are assigned to with the second coordinate pair of any preceding @ draw command, like thus: @<colour>,...,... TO X2,Y2:XC=X2:YC=Y2. Any DRAW TO command then is written as @<colour>,XC,YC TO ...,... - and XC,YC are afterwards updated (again) with the new second coordinate pair.
Note the variable names above are only suggestions. If they clash with existing variables in the program, use other names.
In Super Expander (or BASIC V3.5/V7), the DRAW TO command is just a shortcut where the draw command remembers the previous position of the "graphics cursor" and uses it as start point.armypavarmy wrote:The problem is that Minigrafik does not have the command: Draw TO X, Y.
- Vic 20 Hobbyist
thanks mike
in this listing
example:
first origin with point 1,100,100
after only the draw to x, y command
as I do with Minigrafik
I have to write @ 1,100,100 to x, y
and then ?
I should write @ 1,100,100
and then @ 1 to x, y
but it is not possible.
Minigrafik that I have does not accept
also multiple TO
I don't know how to do it any other way
Thanks Armando
in this listing
example:
and then ?
also multiple TO
Thanks Armando
