Values for SYS command and use/call in ML code
MIRKOSOFT
Website: http://www.mirkosoft.sk
Post by MIRKOSOFT »
Hi!
I was searching commented ROM/RAM disassemply/map for:
- value for A, X, Y register for SYS command - success - found
- value SP for SYS command - success - found
- SYS routine address - success found
- LO and HI byte for use with SYS command as address - never found
Like we know SYS command can be performed with preloaded register values and even preform in ML code using LO and HI byte.
So, Q is: Where are in RAM located LO and HI bytes for address on VIC20 computer?
For complete found info:
C128
0005 SR value for SYS
0006 A reg. value for SYS
0007 X reg. value for SYS
0008 Y reg. value for SYS
0009 SP value for SYS
0002 Bank value for SYS
0003 LO-byte SYS address
0004 HI-byte SYS address
22661 / $5885 SYS
C64
780 $030C A value for SYS
781 $030D X value for SYS
782 $030E Y value for SYS
783 $030F SP value for SYS
20 $0014 LO-byte SYS address
21 $0015 HI-byte SYS address
57642 $E12A SYS
VIC20
783 $030F SR value for SYS
57639 $E127 SYS
C16+4
2034 $07F2 A value for SYS
2035 $07F3 X value for SYS
2036 $07F4 Y value for SYS
2037 $07F5 SR value for SYS
Thank you for help.
Miro
Re: Values for SYS command and use/call in ML code
The C64 uses essentially the same BASIC V2 as the VIC-20, and thus the target address for SYS is also stored in $14/$15 before performing the jump into the pointed to machine code. You find that indirect JMP at address $E141, see here: "registers $030c-$030e".
MIRKOSOFT wrote:C64
This is a typo/wrong: 783 contains the status register SR (or P), not the stack pointer SP (or S) - again same for both VIC-20 and C64.
Why would you want to do this? All registers A, X, Y, S and P are already 'there' without any need to store them to memory and a simple JSR $xxxx suffices to call a subroutine at a fixed address within machine code and of course again return with RTS, with current register values.
I see you're coming from the C128, and there, with JSR JSRFAR a lot more setup is necessary to do inter-bank subroutine calls. The C64 and VIC-20 do not have different RAM banks, and the VIC-20 doesn't even have any layered memory structure (no RAM 'under' ROM), so a simple JSR is all that's needed in 99%+ of all cases.
MIRKOSOFT
Post by MIRKOSOFT »
Ok, thank you very much!
My last Q is to banks...
I'm not writing for C128 bankswitching.
C64 allows to use also space normally under ROM $A000-$BFFF and $E000-$FFFF turn off and use it like RAM.
Difference is to VIC20 that C64 has 6510 CPU.
VIC20 uses 6502 CPU and I don't know if it allows anything similar...
Simply - is possible the space under ROM by any way use like RAM?
If, how to do it?
Thank you very much!
Miro
No, there is no equivalent on the VIC-20, the memory blocks are fixed.
MIRKOSOFT wrote:Simply - is possible the space under ROM by any way use like RAM?
:roll: I already answered this in my post before:
Mike wrote:[...] the VIC-20 doesn't even have any layered memory structure (no RAM 'under' ROM), [...]
If, how to do it?
Simply put, you don't.
BTW, on the C64 it is not the CPU responsible for the selection between RAM, ROM, I/O and character set in the given address ranges. The CPU port of the 6510 merely provides the /LORAM, /HIRAM and /CHAREN signals for the PLA, and it is the PLA which does the main workload of address decoding!
