cc65: How to fill up a segment to a particular size?
Website: http://hugbox.org/
This one is trying to move `continue_to_start` to $2400 – but '.res' wants a constant expression. :( This is *so* retro. ;)
end_of_secondary:
    .res $2400 - end_of_secondary
continue_to_start:
An idea how this can be done anyone? Thanks a million in advance.
(mod: thread moved to 'Emulation and Cross Development' section)
Re: cc65: How to fill up a segment to a particular size?
Normally, this kind of issue is handled via the project's *.cfg, where you define the larger memory areas.
With C, it shouldn't normally be necessary to align parts of a program to a page boundary. Thus I suspect you really want to solve another problem ...
Mike wrote: Wed Sep 30, 2020 1:12 am Normally, this kind of issue is handled via the project's *.cfg, where you define the larger memory areas.
Yep. Need some wrappers to be in BLK1, so it can bank in the rest of the UltiFS. Got this fixed by reordering the segment list. Anyway: there doesn't seem to be a way to enforce the size of a segment which is a bit sad at times.
