runable Graphics wanted...
Hy,
i am playing around with the screenshot feature in VICE a bit, i need runable VIC20 graphics. Preferably something that loads quickly and doesnt require me to press any buttons/keys. Any pointers? :)
Re: runable Graphics wanted...
groepaz wrote:i need runable VIC20 graphics. [...] Any pointers? :)
All MINIGRAFIK/MINIPAINT picture files contain a built-in display routine. Just load them with ",8" (*not* ",8,1"!) with a +8K RAM expansion and then run them.
The *.d64 of the MG batch suite features several picture files, which are normally displayed within a slide show, but you can also view them stand-alone with the method just stated.
thank you, that helped :)
Oh btw, while i am at it... the point of this request was that i am fixing "native" Screenshots - ie C64 "koala" and "hires" formats.
Now the question is - is there a similar common format for vic20 aswell? and can you point to a description of the format, and preferably a pc based tool to display it (for quick testing)?
groepaz wrote:Oh btw, while i am at it... the point of this request was that i am fixing "native" Screenshots - ie C64 "koala" and "hires" formats.
I am the inventor of the aforementioned MG file format, so my view might be somewhat biased, but I think yes, it is the equivalent of *.koa for the VIC-20. There is enough 3rd party use of it to justify the point.
The format has been thoroughly documented in the MINIPAINT manual, in Appendix D, save for the static/boilerplate binary blobs at the begin and end. You get a copy of those with each saved file. ;)
Thus far I didn't consider a PC based viewer, but I can hack together a MG2PPM converter, which also would check the conformity of the static parts. Shall we discuss the details in PM?
I should note that MG displays a 160x192 pixel bitmap, whereas the standard text mode has an equivalent resolution of 176x184 pixels, so you won't be able to screenshot a text screen as MG bitmap.
We already have code to deal with the size differences (either scaling or cropping or adding borders), so that's no problem.
It raises another question though - is there also a "hires" format? :) Or does this work similar to the C64 Textmode, ie mixed hires and mulicolor, toggled by some bit in the color ram?
groepaz wrote:Or does this work similar to the C64 Textmode, ie mixed hires and mulicolor, toggled by some bit in the color ram?
Exactly this. The VIC-I always renders a multi-colour text mode.
OK, fine, should be very doable then :)
groepaz wrote:[...] can you point to a description of the format, and preferably a pc based tool to display it (for quick testing)?
Mike wrote:Thus far I didn't consider a PC based viewer, but I can hack together a MG2PPM converter, which also would check the conformity of the static parts. [...]
Here we go: (download)
You can use the resize function of your favourite image processing tool to apply the correct pixel aspect ratio. ;)
 *  mg_render.c - written 2020-09-17 by Michael Kircher
 *  - validate and render a MG picture file to *.ppm with predefined palette.
#include <stdio.h>
#include <stdlib.h>
#include "image.h"
#define X_SIZE 160
#define Y_SIZE 192
#define FILE_SIZE 4097
typedef enum {false,true} boolean;
RGB vic_palette[16]=
  {  0,   0,   0},  /* Black        */
  {255, 255, 255},  /* White        */
  {148,  23,   1},  /* Red          */
  { 82, 198, 212},  /* Cyan         */
  {144,  28, 204},  /* Purple       */
  { 81, 190,   8},  /* Green        */
  { 49,  26, 213},  /* Blue         */
  {196, 215,  28},  /* Yellow       */
  {163,  81,   0},  /* Orange       */
  {208, 176,  22},  /* Light Orange */
  {233, 121, 105},  /* Light Red    */
  {132, 243, 255},  /* Light Cyan   */
  {221, 115, 255},  /* Light Purple */
  {142, 246,  79},  /* Light Green  */
  {133, 112, 255},  /* Light Blue   */
  {242, 255,  84}   /* Light Yellow */
unsigned char MG_FILE_HEADER[]=
  0xF1, 0x10, 0x0C, 0x12, 0xD8, 0x07, 0x9E, 0x20, 0x38, 0x35,
  0x38, 0x34, 0x00, 0x00, 0x00
unsigned char MG_FILE_FOOTER[]=
  0x18, 0xA9, 0x10, 0xA8, 0x99, 0xF0, 0x0F, 0x69, 0x0C, 0x90,
  0x02, 0xE9, 0xEF, 0xC8, 0xD0, 0xF4, 0xA0, 0x05, 0x18, 0xB9,
  0xE4, 0xED, 0x79, 0xFA, 0x21, 0x99, 0x00, 0x90, 0x88, 0x10,
  0xF3, 0xAD, 0x0E, 0x90, 0x29, 0x0F, 0x0D, 0x0E, 0x12, 0x8D,
  0x0E, 0x90, 0xAD, 0x0F, 0x12, 0x8D, 0x0F, 0x90, 0xA9, 0x10,
  0x85, 0xFB, 0xA9, 0x12, 0x85, 0xFC, 0xA9, 0x00, 0x85, 0xFD,
  0xA9, 0x11, 0x85, 0xFE, 0xA2, 0x0F, 0xA0, 0x00, 0xB1, 0xFB,
  0x91, 0xFD, 0xC8, 0xD0, 0xF9, 0xE6, 0xFC, 0xE6, 0xFE, 0xCA,
  0xD0, 0xF2, 0xA2, 0x00, 0xA0, 0x00, 0xBD, 0x10, 0x21, 0xE8,
  0x99, 0x00, 0x94, 0xC8, 0x4A, 0x4A, 0x4A, 0x4A, 0x99, 0x00,
  0x94, 0xC8, 0xC0, 0xF0, 0xD0, 0xEC, 0x20, 0xE4, 0xFF, 0xF0,
  0xFB, 0x4C, 0x32, 0xFD, 0x02, 0xFE, 0xFE, 0xEB, 0x00, 0x0C
IMAGE *mg_render(unsigned char *raw)
  IMAGE *dst;
  if(NULL != (dst=image_alloc(X_SIZE,Y_SIZE,RGB_IMG)))
    RGB temp,palette[4];
    int x1,x2,y1,y2;
    unsigned char bitmap,colour;
    boolean is_multi,is_inverse=(0 == (raw[-1]&0x08));
    palette[3]=vic_palette[(raw[-2]>>4)&0x0F];
    for(y1=0; y1<Y_SIZE/16; y1++)
      for(x1=0; x1<X_SIZE/8; x1++)
        colour=(raw+X_SIZE*Y_SIZE/8)[((X_SIZE/8)*y1+x1)/2];
        palette[0]=vic_palette[(raw[-1]>>4)&0x0F];
        if(0 == (x1&1))
          palette[1]=vic_palette[colour&0x07];
          is_multi=(0 != (colour&0x08));
        else
          palette[1]=vic_palette[(colour>>4)&0x07];
          is_multi=(0 != ((colour>>4)&0x08));
        palette[2]=vic_palette[raw[-1]&0x07];
        if(is_multi)
          temp=palette[1]; palette[1]=palette[2]; palette[2]=temp;
        else if(is_inverse)
          temp=palette[0]; palette[0]=palette[1]; palette[1]=temp;
        for(y2=0; y2<16; y2++)
          bitmap=raw[Y_SIZE*x1+16*y1+y2];
          if(!is_multi)
            for(x2=0; x2<8; x2+=1)
              rgb_pixel(dst,8*x1+x2,16*y1+y2)=palette[(bitmap>>(7-x2))&0x01];
          else
            for(x2=0; x2<8; x2+=2)
              int x=8*x1+x2,y=16*y1+y2;
              rgb_pixel(dst,x+1,y)=rgb_pixel(dst,x,y)=palette[(bitmap>>(6-x2))&0x03];
  return(dst);
int main(int argc, char *argv[])
  FILE *src;
  IMAGE *dst;
  unsigned char file[FILE_SIZE];
  int i, data;
  if(3 != argc)
    fprintf(stderr,"%s: Syntax: %s <in_file> <out_file>\n",argv[0],argv[0]);
    exit(EXIT_FAILURE);
  if(NULL == (src=fopen(argv[1],"rb")))
    fprintf(stderr,"%s: Error: could not open file \'%s\' for read access.\n",argv[0],argv[1]);
    exit(EXIT_FAILURE);
  for(i=0; i<FILE_SIZE; i++)
    if(EOF == (data=getc(src)))
      fprintf(stderr,"%s: Error: file \'%s\' truncated.\n",argv[0],argv[1]);
      exit(EXIT_FAILURE);
    file[i]=data;
  if(EOF != (data=getc(src)))
    fprintf(stderr,"%s: Error: file \'%s\' over-length.\n",argv[0],argv[1]);
    exit(EXIT_FAILURE);
  fclose(src);
  for(i=0; i<sizeof(MG_FILE_HEADER); i++)
    if(file[i] != MG_FILE_HEADER[i])
      fprintf(stderr,"%s: Error: file \'%s\', header mismatch.\n",argv[0],argv[1]);
      exit(EXIT_FAILURE);
  for(i=0; i<sizeof(MG_FILE_FOOTER); i++)
    if(file[i+FILE_SIZE-sizeof(MG_FILE_FOOTER)] != MG_FILE_FOOTER[i])
      fprintf(stderr,"%s: Error: file \'%s\', footer mismatch.\n",argv[0],argv[1]);
      exit(EXIT_FAILURE);
  if(0 != (file[15] & 0x0F))
    fprintf(stderr,"%s: Error: file \'%s\' saved with non-0 audio volume.\n",argv[0],argv[1]);
    exit(EXIT_FAILURE);
  dst=mg_render(file+17);
  image_save(dst,argv[2]);
  image_free(dst);
  exit(EXIT_SUCCESS);
Website: http://hugbox.org/
Mike wrote: Fri Sep 18, 2020 5:42 am Here we go: (download)
Hey, thant's great! If you don't mind I slap on an open-source license of your choice, refurbish it a bit, add a make script for Unices and put it on Github. :)
pixel wrote:Hey, thant's great! If you don't mind I slap on an open-source license of your choice, refurbish it a bit, add a make script for Unices and put it on Github. :)
@pixel: PM sent.
For the interested parties: "image.c", "image.h" and "matrix.h" are licenced with CC0, and "mg_render.c" is licenced with CC-BY-SA.
Mike wrote: Wed Sep 23, 2020 1:35 am For the interested parties: "image.c", "image.h" and "matrix.h" are licenced with CC0, and "mg_render.c" is licenced with CC-BY-SA.
It's been finished a couple of days ago – if someone could tell me how (what text) to include these licenses in the sources that'd be much of a help.
Here is the unixoid version: https://github.com/SvenMichaelKlose/mg_render with Windoze executable included.
Took some extra time because of a lot of regular work and then something that could've been COVID knocked me out for the better part of the week.
Oookay, i finally found the time to actually add this :)
https://sourceforge.net/p/vice-emu/code/39977/
Not perfect yet, Hires blocks not handled at all right now. The algorithm that chooses the common/shared colors can probably be improved. The tables used for color substitution are kindof bad. Patches welcome :)
Find an ad hoc build for windows here: https://github.com/VICE-Team/svn-mirror ... tag/r39977
Cheers :)
ops
Post by ops »
Thanks, interesting feature. I just tested on Linux.
Multicolor seems pretty OK but hires needs to be supported to get decent screenshots from games.
