Integrate with the host platforms filesystem (Linux)
wimoos
Occupation: farmer
Post by wimoos »
All,
Has anyone ever tried to integrate VIC with the host platform through the filesystem ? That is, in linux do:
ln -s /dev/urandom rnd
xvic
and then in VICE
10 OPEN1,8,0,"RND"
20 GET#1,A$:IFA$=""THENA$=CHR$(0)
30 PRINTASC(A$)
40 IFST=0THEN20
50 CLOSE1
This works. Also the /proc area might be useful.
Unfortunately, I can't get opening a named pipe to work. It makes VICE hang, so that is doesn't respond anymore. Anybody a clue ?
Regards,
Wim.
Re: Integrate with the host platforms filesystem (Linux)
It probably is opening the file in blocking mode, what does strace tell you?
wimoos
Occupation: farmer
Post by wimoos »
Hello srowe
Thanks to strace , I now see that VICE opens files with the syscall openat() and does not use the O_ASYNC flag that is needed when addressing a pipe.
Regards,
Wim.
Make a feature request, perhaps :)
I just tried this by creating the RND symlink in my ~/vic20/ VICE virtual device directory, and running your BASIC program. It works just fine, I get an output of random numbers.
