Split cost of keyboard repair?
Vic 20 Item Exchange
Is there anyone in the UK that would be interested in going halves on this
https://www.amazon.co.uk/RUBBER-KEYPAD- ... B002BZK06G
The keyboard in my original VIC is very temperamental, this stuff should to do a good quality repair but seems expensive for just a single system. Given it has a 72 hour life after mixing I think it should be possible to use it and then post it to someone else to use.
Noizer
Re: Split cost of keyboard repair?
Post by Noizer »
How does it work?
Noizer wrote: Tue Aug 11, 2020 11:15 am How does it work?
It's a special conductive paint, detailed explanation here
https://www.youtube.com/watch?v=7x-4590yWVY
There are cheaper types but I think this one has been recommended on Denial before.
r.cade
Post by r.cade »
Unless you have the little round pads like the PET keyboard, it will not work.
The rubber part of the VIC/C64 keyboard is a flexible oddly-shaped contact and this coating will just come off.
Pull all the key stems and drop them in a bowl of amonia. Leave for 3-4 days, then rinse them off with alcohol and let dry.
They will work again - it revives the conductive rubber.
Cheap and easy.
Pete Rittwage
C64 Preservation Project
http://c64preservation.com
Interesting, yes, it is the original PET keyboard.
I've not heard of using ammonia, any link to more detailed instructions?
r.cade
Post by r.cade »
srowe wrote: Tue Aug 11, 2020 11:49 pm Interesting, yes, it is the original PET keyboard.
https://www.youtube.com/watch?v=n9gGz2n-sBU
Pete Rittwage
Very informative, I'll try this before shelling out on the repair kit.
OK, so I finally got around to trying this. I've done two PET keyboards and they've come out like new.
My method was as follows, 48 hours in 3% ammonia, wash with water, 24 hours in IPA, couple of hours air dry.
I had to also clean one PCB with pencil rubber plus IPA, just alcohol alone wasn't enough.
