CRT version of FB64?
Does anyone have a CRT formatted version of FB64 or a similar file browser? I want to put it on my EasyFlash 3.
I've been unable to use the converters (like https://github.com/lvcabral/cart64-maker) because I'm using a chromebook. :cry:
Re: CRT version of FB64?
AFAIK, FB64 is too large to be converted using cart64-maker. This specific converter creates .crt images that are limited to 16kB.
eslapion wrote: Mon Jul 27, 2020 10:34 pm AFAIK, FB64 is too large to be converted using cart64-maker. This specific converter creates .crt images that are limited to 16kB.
Thanks for the info. Do you know of any other file browsing options in crt form I could put on the EF3?
Jeff-20 wrote: Tue Jul 28, 2020 2:53 am
IIRC, there is a version of Fast Hack'em in .CRT format but I don't think this has all the features you'd want to have.
Wouldn't a Super Snapshot or Final Cartridge .CRT do what you want ?
Hi, Jeff,
Jeff-20 wrote:Does anyone have a CRT formatted version of FB64 or a similar file browser? I want to put it on my EasyFlash 3.
There's a (or the?) EasyFlash Tool Collection to be found at CSDb, here:
One of the included tools is SD2BRWSE, which pretty much should fit your inquiry.
Michal
Mike wrote: Tue Jul 28, 2020 8:32 am Hi, Jeff,
Michal
Thank you! That works well.
I also had this one recommended to me on Lemon... https://we.tl/t-ZXJ4PF4Z65
It works well and requires fewer steps to get to the browser, but is it possible for the software to assume drive 8? I still have to access the keyboard to select the drive.
nbla000
Salmon Run
Post by nbla000 »
FB64 is the C64 version of my CBM-FileBrowser pratically used in all sd2iec firmware based devices while EasyFlash 3 seems a c64 cartridge to store other cartridge with his browser I guess, in which way do you wish to use FB64 with EasyFlash 3?
The only mode that comes in my mind is to select the JiffyDOS kernal and from the C64 prompt just LOAD"FB64",8 + RUN if FB64 is on SD drive, I don't know if EF3 acts as drive too and wich drive # uses but FB64 uses the drive # where is loaded from.
nbla000 wrote: Tue Mar 30, 2021 6:37 am FB64 is the C64 version of my CBM-FileBrowser pratically used in all sd2iec firmware based devices while EasyFlash 3 seems a c64 cartridge to store other cartridge with his browser I guess, in which way do you wish to use FB64 with EasyFlash 3?
I was just lazy and wanted to load a game from sd2iec quickly without using the keyboard... :oops: :)
