Building a tape image with several files / parts ?
- AndyH
- Occupation: Developer
I am trying to create a tape image that is made up of three files. The first would be a small loader program (a little bit of machine code) that would then load in part 2 at a memory address. Later, I would load in part 3 at a memory address.
I want to create a single TAP image that conatins: Loader -- Part 2 -- Part 3
Loader, Part 2 and Part 3 are currently PRG files.
I've found loads of tools that let you do things with tape but so far none that will let me do what I need, they mostly focus on single PRG's or extraction and cleaning up. Can anyone recommend a tool for Windows that would let me build up a tape file from three prgs?
Re: Building a tape image with several files / parts ?
I've been experimenting with Python scripts to extract files from .tap files. Doing the reverse shouldn't be that hard.
If it's a one-time only, you can put them to disk (.D64) and then save to tape one the VICE emulator and then get the .tap file.
If you want to a generic concatenation tool, I'm afraid you have to write your own. It's not that difficult, .TAP files have a small and simple header, you can skip the headers, join the three data blocks and then build a new header. See here
- AndyH
Thanks both!
Nippur72 - after that header comes the file data, but I'm not sure what it is saying. There's an explanation of each version $00 or $01 but how do you determine what to actually write to the file?
ie:
So my byte of data is 47, what do I need to write into the TAP file to represent it?
ie:
Therefore, a data value of $2F (47 in decimal) would be:
(47 * 8) / 985248 = .00038975 seconds.
- AndyH
Another approach I have tried is to save from the VICE monitor. I can save to device 0 to save a block of memory to my Windows file system and that works, but swap out for device 1 and I get the Cannot open error:
(C:$a34e) s "P2" 1 a000 bfff
Cannot open P2.
This is with a newly created TAP image created and attached via VICE.
Cannot open P2.
Ok I think I have misunderstood your original question, I thought you had 3 .TAP files and wanted to make a single one.
If you instead have three data files (e.g. normal bytes) and want to create a TAP file, then the process is a lot more complex.
Every byte has to be split into bits, and every bit turn into pulses of various lengths. What you actually write on the output file is the length of each single pulse. It's not difficult, only tedious. But you have to strictly adhere to the protocol otherwise your file won't load. I suggest you to generate the .TAP files with one of the existing tools and then concatenate them.
- AndyH
Understood, and yes I was wondering about that when reading about the pulses.
Some success ... with WAV-PRG and AudioTap I can convert to various formats including TAP. So I can construct the header and copy raw data for each converted PRG. Examining the data in a hex editor I can see the corresponding patterns.
Perhaps making it easier (in a way) is this tool supports export/import to WAV sound files, so just a case of splicing three WAV files together, before converting back to a long TAP file.
Conversion to WAV and back to TAP is working, so just need to test my code to see if it all works together.
Building a multi-file tape can be done with the native tool set. In VICE, attach both a source *.d64 and an empty target *.tap file and then run the following small program:
Replace the file names in the DATA lines as appropriate. The program (plus its variables) need to run in a place that's not used by the data being transferred from disk to tape. If, for example, BLK5 is spare, issue the following POKEs to relocate the BASIC workspace to BLK5:
POKE43,1:POKE44,160:POKE40960,0:POKE55,0:POKE56,192:NEW
After the first file has been loaded from disk, you'll be prompted to PRESS RECORD & PLAY ON TAPE. From then, all files will continuously be written into the *.tap file.
Note: this program only works for PRG files (i.e. memory dumps in the farthest sense). Tape SEQ files are recorded in another format and need a different handling.
10 READN$
11 IFN$=""THENEND
12 OPEN2,8,0,N$
13 GET#2,A$,B$
14 CLOSE2:PRINTN$
15 S0=ASC(A$+CHR$(0))
16 S1=ASC(B$+CHR$(0))
17 SYS57809(N$),8,1
18 POKE780,0:SYS65493
19 E0=PEEK(781)
20 E1=PEEK(782)
21 SYS57809(N$),1,0
22 POKE193,S0
23 POKE194,S1
24 POKE780,193
25 POKE781,E0
26 POKE782,E1
27 SYS65496:GOTO10
28 :
29 DATA "FILE1"
30 DATA "FILE2"
31 DATA "FILE3"
32 DATA ""
- AndyH
WOW thanks Mike.
This looks perfect. As I will be making a disk version also (and that part is easy), this will speed things up somewhat. My files are all prg's (or prg-like).
I've just been testing my loader with part 2 coming from tape so will be ready to put the two together.
Mike's code is pure wizardry
This guy never ceases to amaze!
- AndyH
The above would be a great topic for the Denial Journal.
