Key cap repair
Key cap repair
I've managed to acquire a Eurostile keyboard, unfortunately someone has botched repairing one of the function keys
I'm trying to work out how best to repair it. I have two thoughts.
1. rebuild the "cross head" with epoxy, for this I need a form in place of the plunger top and something as a mold release so it's not permanently stuck
2. create a "cross head" insert and glue it in the key cap
For both these I really need to build a jig to get the alignment in 3D correct.
I don't have a 3D printer so any solution will have to be done by hand. Any better thoughts how I can do this?
Re: Key cap repair
Play Doh? Something that will mold over the cross, then dry hard to provide support, but won’t stick to the shaft.
Re: Key cap repair
Air dry modelling clay perhaps? I'm struggling to think of a way to create a jig. I could use another key, back-to-back, but then need a cross-shaped shaft to form the hole in the key.
Re: Key cap repair
Post by Vic20-Ian »
Try a Lego Axle
Re: Key cap repair
Vic20-Ian wrote: Thu Jun 25, 2020 7:57 am Try a Lego Axle
Ooh, I wonder if I can (ab)use something like this?
https://www.brickowl.com/catalog/lego-a ... -hole-6538
Re: Key cap repair
Post by Vic20-Ian »
