Union Jack / lock-down challenge, draw your country's flag..
Feeling bored so decided to do a little Super-Expander coding for the first time in 40 years. Please feel free to add your own country's flag to this thread.
Code:
5 rem Union Jack Beamrider 05-june-2020
10 graphic 1
20 color 6,0,1,2
30 scnclr
40 h = 1024 * .65 : w = 1024: mh = h-1: mw = w-1
50 for s = mh+5 to 1024 step 6
60 draw 1,0,s to mw,s
70 next
80 wdcw  = h / 5 : u = wdcw / 6
90 for s = 0 to 3 step 0.25
100 draw 2,s*u,0 to mw, mh-s*u
110 draw 2,0,s*u to mw-s*u, mh
120 draw 2,0,mh-s*u to mw-s*u,0
130 draw 2,s*u,mh to mw,s*u
140 next s
160 for s = 0 to 2 step 0.25
170 draw 3,0,s*u to w/2, (h/2)+s*u
180 draw 3,s*u,mh to w/2, (h/2)+s*u
190 draw 3,w/2,(h/2)-s*u to mw-s*u , 0
200 draw 3,w/2,(h/2)-s*u to mw , mh - (s*u)
210 next s
220 for s = 0 to 4 step 0.15
230 draw 2,0,(h/2)+s*u to mw,(h/2)+s*u
240 draw 2,0,(h/2)-s*u to mw,(h/2)-s*u
250 draw 2,w/2+s*u ,0 to w/2+s*u ,mh
260 draw 2,w/2-s*u ,0 to w/2-s*u ,mh
270 next s
280 for s = 0 to 2 step 0.15
290 draw 3,0,(h/2)-s*u to mw,(h/2)-s*u
300 draw 3,0,(h/2)+s*u to mw,(h/2)+s*u
310 draw 3, w/2-s*u,0 to w/2-s*u,mh
320 draw 3, w/2+s*u,0 to w/2+s*u,mh
330 next s
created with CbmPrg!
Re: Union Jack / lock-down challenge, draw your country's flag..
This is too easy :-)
0 printchr$(147)chr$(18)chr$(144);:gosub2:printchr$(28);:gosub2:printchr$(158);:gosub2
1 poke198,0:wait198,1:end
2 fori=1to154:print" ";:next:return
beamrider wrote:[...] a little Super-Expander coding [...]
Wrong BASIC extension. ;)
For most flags, putting three coloured stripes on screen shouldn't be too difficult, and tokra has anyhow done it already for the German flag (Black, Red, Gold), so here's my rendition of the Union Jack in MINIGRAFIK (download):
1 V=36864:POKEV+14,32:POKEV+15,104:POKE646,9:@ON:@CLR
2 FORY=14TO44:@1,0,YTO159,Y+133:@1,0,Y+133TO159,Y:NEXT
3 FORY=29TO39:@3,0,YTO79,Y+66:@3,0,Y+133TO79,Y+67:NEXT
4 FORY=19TO29:@3,159,YTO80,Y+66:@3,159,Y+133TO80,Y+67:NEXT
5 FORY=73TO118:@1,0,YTO159,Y:NEXT:FORY=29TO162:@1,66,YTO92,Y:NEXT
6 FORY=82TO109:@3,0,YTO159,Y:NEXT:FORY=29TO162:@3,72,YTO86,Y:NEXT
7 FORY=0TO28:@2,0,YTO159,Y:@2,0,191-YTO159,191-Y:NEXT
8 FORP=-1TO0:GETA$:P=A$="":NEXT:@RETURN
This is a bit stylized and simplistic, but so are we.
This one gets the middle red stripe right:
1 PRINT"{BLU,3 C=-POUND,RED,4 C=-I,C=-F}"
2 FORT=1TO3:PRINT"{BLU,3 C=-+,RED,4 C=-I,C=-F}":NEXT
3 FORT=1TO3:PRINT"{RED,7 C=-I,C=-F,BLU}":NEXT
chysn wrote:This is a bit stylized and simplistic, but so are we.
Though it may become valid on this zoom step, should the US ever grow to 336 States. :shock:
... :mrgreen:
Here's my US one. I opted for C and made use of my screen-designer in this example. I went a bit OCD on getting the line height correct and a border around the stars.
Attached is the .prg for the unexpanded Vic and source files. I haven't tested it on real hardware so not sure if the screen geometry is correct for all displays.
#include <conio.h>
#include <vic20.h>
#define NULL 0
#define FALSE 0
#define TRUE !FALSE
#define COLORRAM 0x9600
#define SCREENRAM  0x1E00
#define VERT_OFFSET 36
#define HORZ_OFFSET 8
#define COL_COUNT 26
#define LINE_COUNT 19
#define LINE_COUNT_MASK 0x81
#define COL_COUNT_MASK 0x80
#define SCREENDATA_ENDMARKER  0x40
#define SCREENDATA_RLEINDICATOR 0x80
typedef unsigned char BYTE;
typedef unsigned char BOOL;
extern BYTE ScreenData[];
extern BYTE ColourData[];
void InitVICSettings();
void plotValuesRLE(BYTE x, BYTE y, BYTE* pData, BYTE* target);
void main (void)
	InitVICSettings();
	plotValuesRLE(0,0,ScreenData, SCREENRAM);
	plotValuesRLE(0,0,ColourData, COLORRAM);
	while(1);
	BYTE tmp;
	// Set the screen colours
	textcolor (COLOR_RED);
	bordercolor (COLOR_BLACK);
	bgcolor (COLOR_WHITE);
	VIC.volume_color = (COLOR_RED << 4) | (VIC.volume_color & 0x0F);
	// Set the screen geometry
	VIC.addr = (VIC.addr & 0xF0) | 0x0E; // 128 chars at $1800
	VIC.leftborder = HORZ_OFFSET;
	VIC.charsperline = (VIC.charsperline & COL_COUNT_MASK) | COL_COUNT;
	VIC.upperborder = VERT_OFFSET;
	VIC.linecount = (VIC.linecount &  LINE_COUNT_MASK) | (LINE_COUNT << 1);
	int index = 0;
	int screenIndex = 0;
	int rleCount = 0;
	BYTE rleIndex = 0;
	BYTE value = 0;
	while (pData[index] != SCREENDATA_ENDMARKER)
		if (pData[index] >=  SCREENDATA_RLEINDICATOR)
			value = pData[index] & ~SCREENDATA_RLEINDICATOR;
			rleCount = 1;
		else
			rleCount = pData[index];
			index++;
			value = pData[index];
		for (rleIndex = 0; rleIndex < rleCount; rleIndex++)
 			target[screenIndex++] =  value;
		index++;
USFlag.zip
(4.11 KiB) Downloaded 42 times
Mike wrote: Fri Jun 05, 2020 1:55 pm
Yes, yours is more powerful, but SE was chosen for nostalgic reasons :D
tokra wrote: Fri Jun 05, 2020 12:47 pm This is too easy :-)
You could always make it more difficult using raster-splits instead :D
And here is Canada.
Same code as US but with different display data.
;settings
;background-colour=1
;border-colour=0
;aux-colour=2
;rle-encoded=true
;char-height=8
;row-count=20
;col-count=24
;char data
CharData:
udc0: .byte  $07,$03,$03,$01,$00,$00,$00,$00
udc1: .byte  $FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF
udc2: .byte  $00,$00,$00,$00,$00,$00,$00,$00
udc3: .byte  $00,$20,$3C,$3F,$3F,$1F,$1F,$1F
udc4: .byte  $1F,$1F,$0F,$0F,$0F,$0F,$0F,$07
udc5: .byte  $07,$07,$07,$07,$03,$03,$07,$07
udc6: .byte  $1F,$3F,$7F,$7F,$3F,$1F,$1F,$0F
udc7: .byte  $01,$01,$01,$81,$F3,$FF,$FF,$FF
udc8: .byte  $FF,$FF,$FF,$FF,$FF,$FF,$FF,$FF
udc9: .byte  $FF,$FF,$FF,$FF,$FF,$7F,$7F,$3F
udc10: .byte  $1F,$0F,$0F,$07,$03,$01,$01,$00
udc11: .byte  $00,$00,$00,$00,$C0,$C0,$E0,$E0
udc12: .byte  $F0,$F0,$F8,$FC,$FC,$FE,$FE,$FF
udc13: .byte  $7F,$3F,$3F,$1F,$0F,$0F,$07,$07
udc14: .byte  $0F,$0F,$0F,$0F,$1F,$1F,$1F,$1F
udc15: .byte  $1F,$38,$00,$00,$00,$00,$00,$00
udc16: .byte  $00,$00,$00,$00,$00,$80,$C0,$E0
udc17: .byte  $F0,$F8,$FC,$FF,$7F,$7F,$7F,$7F
udc18: .byte  $7F,$7F,$7F,$7F,$3F,$3F,$3F,$3F
udc19: .byte  $3F,$3F,$3F,$3F,$3F,$1F,$1F,$1F
udc20: .byte  $1F,$1F,$1F,$1F,$1F,$0F,$0F,$0F
udc21: .byte  $0F,$8F,$8F,$FF,$FF,$FF,$FF,$FF
udc22: .byte  $FF,$FF,$FF,$FF,$FF,$FF,$FF,$F0
udc23: .byte  $80,$00,$00,$00,$00,$00,$00,$00
udc24: .byte  $00,$00,$00,$00,$01,$01,$03,$03
udc25: .byte  $03,$03,$07,$07,$07,$0F,$0F,$0F
udc26: .byte  $1F,$1F,$1F,$3F,$3F,$3F,$3F,$7F
udc27: .byte  $7F,$7F,$FF,$FF,$FF,$FF,$FF,$FF
udc28: .byte  $FF,$FF,$FF,$FF,$FF,$E7,$03,$03
udc29: .byte  $03,$03,$03,$03,$03,$03,$03,$03
udc30: .byte  $03,$03,$03,$03,$07,$07,$00,$00
udc31: .byte  $80,$80,$80,$C0,$C0,$C0,$E0,$E0
udc32: .byte  $E0,$F0,$F0,$F0,$F0,$F8,$F8,$F8
udc33: .byte  $FC,$FC,$FC,$FF,$FF,$FF,$FF,$FF
udc34: .byte  $FF,$FF,$FF,$FF,$FF,$9F,$81,$00
udc35: .byte  $00,$80,$80,$80,$80,$80,$80,$80
udc36: .byte  $80,$80,$80,$80,$80,$80,$80,$80
udc37: .byte  $80,$80,$80,$80,$80,$80,$00,$00
udc38: .byte  $00,$00,$00,$00,$00,$02,$06,$0E
udc39: .byte  $1C,$3C,$7C,$FC,$FC,$FC,$FC,$FC
udc40: .byte  $FC,$F8,$F8,$F8,$F8,$F8,$F8,$F8
udc41: .byte  $F8,$F0,$F0,$F0,$F0,$F0,$F0,$F0
udc42: .byte  $F0,$F0,$E0,$E0,$E0,$E0,$E1,$E1
udc43: .byte  $E3,$E3,$E7,$FF,$FF,$FF,$FF,$FF
udc44: .byte  $FF,$FF,$FF,$FF,$FF,$FF,$FF,$3F
udc45: .byte  $03,$00,$00,$00,$00,$00,$00,$00
udc46: .byte  $00,$00,$00,$00,$04,$0C,$0E,$1E
udc47: .byte  $1E,$3E,$3F,$7F,$7F,$FF,$FF,$FF
udc48: .byte  $FF,$FF,$FF,$FF,$FF,$FF,$FE,$FE
udc49: .byte  $FC,$F8,$F0,$F0,$E0,$C0,$C0,$C0
udc50: .byte  $C0,$E0,$E0,$E0,$E0,$E0,$F0,$F0
udc51: .byte  $F0,$70,$00,$00,$00,$00,$00,$00
udc52: .byte  $00,$00,$00,$03,$1F,$FF,$FF,$FF
udc53: .byte  $FF,$FF,$FF,$FF,$FE,$FC,$F8,$F8
udc54: .byte  $F0,$E0,$C0,$C0,$80,$00,$00,$00
udc55: .byte  $00,$18,$F8,$F0,$F0,$F0,$F0,$F0
udc56: .byte  $E0,$E0,$E0,$E0,$E0,$C0,$C0,$C0
udc57: .byte  $C0,$C0,$80,$80,$80,$80,$80,$C0
udc58: .byte  $E0,$F8,$FC,$FC,$F8,$F0,$E0,$E0
udc59: .byte  $C0,$80,$00,$00,$00,$00,$00,$00
udc60: .byte  $7C,$22,$22,$3C,$22,$22,$7C,$00
;screen data0
ScreenData0:
.byte  $06,$01,$0C,$02,$0C,$01,$05,$02
.byte  $98,$06,$02,$0C,$01,$05,$02,$99
.byte  $9F,$05,$02,$0C,$01,$04,$02,$90
.byte  $9A,$A0,$A6,$04,$02,$0C,$01,$04
.byte  $02,$91,$9B,$A1,$A7,$04,$02,$0C
.byte  $01,$04,$02,$92,$02,$08,$A8,$04
.byte  $02,$0C,$01,$03,$02,$8B,$93,$02
.byte  $08,$A9,$AE,$03,$02,$0C,$01,$82
.byte  $83,$87,$8C,$94,$02,$08,$AA,$AF
.byte  $B4,$B7,$82,$0C,$01,$82,$84,$02
.byte  $08,$95,$02,$08,$AB,$02,$08,$B8
.byte  $82,$0C,$01,$82,$85,$08,$08,$B9
.byte  $82,$0C,$01,$82,$86,$08,$08,$BA
.byte  $82,$0C,$01,$82,$80,$89,$06,$08
.byte  $B5,$BB,$82,$0C,$01,$02,$02,$8A
.byte  $05,$08,$B0,$B6,$02,$02,$0C,$01
.byte  $03,$02,$8D,$04,$08,$B1,$03,$02
.byte  $0C,$01,$03,$02,$8E,$96,$9C,$A2
.byte  $AC,$B2,$03,$02,$0C,$01,$03,$02
.byte  $8F,$97,$9D,$82,$AD,$B3,$03,$02
.byte  $0C,$01,$05,$02,$9D,$A3,$05,$02
.byte  $0C,$01,$05,$02,$9D,$A4,$05,$02
.byte  $0C,$01,$05,$02,$9E,$A5,$05,$02
.byte  $0C,$01,$0C,$02,$06,$01
;colour data0
ColourDataScreen0:
.byte  $7F,$02,$7F,$02,$7F,$02,$63,$02
CanadaFlag.zip
(1.07 KiB) Downloaded 33 times
That's some beautiful work there. I couldn't resist giving this the minimalist treatment. I love Canada so much. We used to be able to just cross the bridge whenever we wanted. Now we have to grab our passports. Still, if you ever get a chance to get to Point Pelee to see the monarchs prep for migration, it's quite a sight.
chysn wrote: Sat Jun 06, 2020 11:26 pm That's some beautiful work there. I couldn't resist giving this the minimalist treatment. I love Canada so much. We used to be able to just cross the bridge whenever we wanted. Now we have to grab our passports. Still, if you ever get a chance to get to Point Pelee to see the monarchs prep for migration, it's quite a sight.
Thanks..
I like your flag too - small but perfectly formed.
Yes, Canada is great, I've been once to Toronto and visited their side of the Niagara falls.
btw, what tool are you using to enter the assembler?
beamrider wrote:btw, what tool are you using to enter the assembler?
This is chysn's own wAx, which he wrote just recently.
Mike wrote: Sun Jun 07, 2020 4:02 am
Thanks, looks interesting, will take a look.
beamrider wrote: Sun Jun 07, 2020 6:52 am
It's what happens when VICMon drives a man to the edge. It was either this or lots and lots of vodka. https://github.com/Chysn/wAx/wiki
But the work of the world continues...
aitsch
Post by aitsch »
not really one country 8)
*=$1001
!byte $0b,$08, $e2,$07, $9e, $20, $34, $31, $31, $30, $00,$00, $00
screen=$1e49
color=$9649
; --------- init -----------
                          lda #$fe          ; custom char har at $1800
                          sta $9005
                          lda #147
                          jsr $ffd2
                          ;cpy char rom
                          ldx #1
                          ldy #0
 .rom_char                lda $8000,y
 .cust_char               sta $1800,y
                          lda #7
                          sta color,y
                          dey
                          bne .rom_char
                          inc .rom_char+2
                          inc .cust_char+2
                          dex
                          bpl .rom_char
                          ; modify char
                          ldy #39
  .loop1                  lda char,y
                          sta $1950,y
                          dey
                          bpl .loop1
!zone draw
  draw                    ; stars
                          ldy #8
  .initx                  ldx #8
  .loop                   lda flag,x
                   srn    sta screen,x
                          dex
                          bpl .loop
                          lda #9
                          adc .loop+1
                          sta .loop+1
                          lda srn+1
                          adc #22
                          sta srn+1
                          dey
                          bpl .initx
                          ; Text
                          lda #0
                          sta $0286
  .text                   ldx #16
                          ldy #0
                          clc
                          jsr $fff0
                          ldx #$00
  .loop_text              lda europe,x
                          beq main
                          jsr $ffd2
                          inx
                          jmp .loop_text
!zone main
main
                          lda $9004
                          cmp #88
                          bpl .color1
                          lda #105
                          bne .fill
  .color1                 lda #25
  .fill                   sta $900f
                          jmp main
; --------- data
flag
  !text "    +    "
  !text "  * , *  "
  !text " +     + "
  !text " ,     , "
  !text ".-     .-"
  !text " +     + "
  !text " ,     , "
  !text "  * + *  "
  !text "    ,    "
europe
    !text "EUROPE"
char
!byte  $00,$66,$3c,$ff,$3c,$66,$00,$00
!byte  $00,$00,$00,$00,$00,$66,$3c,$ff
!byte  $3c,$66,$00,$00,$00,$00,$00,$00
!byte  $00,$60,$c0,$f0,$c0,$60,$00,$00
!byte  $00,$06,$03,$0f,$03,$06,$00,$00
