one of the most frustrating fact for me when i programming games for the vic-20 is that there seems to be no possibility to overlap the grafics (characters).
today i've looked some youtube videos about "new" games for vics and it seems that some titles make these overlaps of their characters.
maybe i am wrong and they didn't use modified characters for their grafics but it was enough for me to place my question here.
so are there known technics for overlapping or other tricks to make the illusuion of it or something to alleviate that one character delete the other?
aitsch
is there a trick to overlap characters
Re: is there a trick to overlap characters?
The programs in question inevitably work with a pool of user defined characters.
Not only are the movable objects placed in their own small bitmap (which then allows for pixel-wise movement), but background objects and other moving objects are merged into said bitmap. This merge procedure either uses EOR (rather crude), OR (somewhat o.k.ish) or AND NOT mask + EOR pattern, the latter which allows for all four possible single pixel operations: set, reset, invert, leave alone ('transparent').
And no, the VIC-I does not have any extra DMA channels which allow for hardware sprites. You need to do everything in software. And attribute, i.e. colour clash will occur regardless.
Edit: some games 'flicker' two characters on alternate frames. That might 'trick' some people into seeing merged characters, but ultimately, they still flicker.
- AndyH
- Occupation: Developer
There is code and other information available on Denial to do a lot of these tricks if you search around. Mike (and others) have also created a program that extends BASIC to generate a full screen bitmap mode using re-definable characters. Good place to start is here: http://sleepingelephant.com/ipw-web/bul ... f=2&t=6338
I've created what I call VBM (Vic Bitmap Mode) using these principals in Turbo Rascal http://turborascal.com that abstract a lot of the technical and set up stuff and provide a number of commands for working on the bitmap, including software sprites. You can do all the display modes mentioned above.
I'm currently looking at add 'local' bitmap mode support to Turbo Rascal, using the method Mike describes above, which has its own advantages and disadvantages.
thanks for your answers.
now i know there is no spuky and magic trick outside to overlap characters.
what i already knew is, that there are no hardware sprites in VIC-I chip but thanks for reminding
i've played around with ORA to overlap a moving character with background grafics, inspired of your ideas.
the soloution works as follows:
- the original characters in the FROM- and TO-positions will be copied to separate addresses and modified there
- the bitwise movement is done invisible in separate addresses (tape buffer), lets say shadow movement.
- after a step is done (8 x 1 pixel wide), ORA matches the current shadow movement with the original background char to the character FROM and character TO adresses.
- when the movement is finished the FROM position will be exchanged with the original character
here is my simple result:
and yes, this code is not perfect. it should only show how it could work.
the music plays in this two methods:
- prepareCharMovement
- moveRight
the advantage is, that this technique is acceptable for static background grafics in simple games.
the detriment is, that the background always need to have the same color like the moving character.
what do you think about it?
aitsch
; ################# addresses ###################
BSOUT=$ffd2
zp=$fd
zp2=$fb
tmp=$02
tmp2=$42
adrCharFrom=$1200
adrCharTo=$1208
adrCharMaster=$1210
adrCharToTmp=$0334
adrCharFromTmp=$033c
; ############### character vars ################
dir=$aa
olddir=$ab
xpos=$ac
ypos=$ad
oldxpos=$ae
oldypos=$af
action=$b0
backgrnd=$b1
oldbackgrnd=$b2
; #################### const ####################
UP=0
DOWN=UP+1
LEFT=UP+2
RIGHT=UP+3
SPEED=$20
CHAR=64
; ######### addresses for shadow movement ########
*=$0334
!byte $00,$00,$00,$00,$00,$00,$00,$00 ; char FromTmp
!byte $00,$00,$00,$00,$00,$00,$00,$00 ; char ToTmp
; ####### working characters #######
*=$1200
!byte $18,$4c,$26,$1f,$26,$4c,$18,$00 ; char Master
*=$1001
!byte $0b,$08, $e2,$07, $9e, $20, $34, $38, $36, $34, $00,$00, $00
*=$1300
jsr init
; # Main
!zone main
main
jsr prepareCharMovement
jsr moveRight
dec stepCount
bpl main
jsr init.restart
jmp main
;rts
stepCount
!byte $00
; # shift character to right dir
!zone prepareCharMovement
prepareCharMovement ; load old original background character and set address
lda backgrnd
sta oldbackgrnd
cmp #32
bmi .asl_0
inc oldBackgndAdr+2 ; inc HiByte
.asl_0 asl
asl
asl ; *8
sta oldBackgndAdr+1
; load Character position
ldy xpos
sty oldxpos
ldx ypos
stx oldypos
lda #CHAR
jsr printChar
iny ; step right
sty xpos
lda (zp),y
sta backgrnd ; save new original background character
cmp #32
bmi .asl_1
inc backgnd_adr+2 ; inc HiByte
inc newBackgndAdr+2 ; inc HiByte
.asl_1 asl
asl
asl ; * 8
sta backgnd_adr+1 ; set backgrund address
sta newBackgndAdr+1 ; set backgrund address
ldx #7
; copy backgrund char to new Position (CharTo)
backgnd_adr lda $1000,x
sta adrCharTo,x
; copy Master to Tmp
lda adrCharMaster,x
sta adrCharFromTmp,x
lda #0 ; delete CharTmp
sta adrCharToTmp,x
dex
bpl backgnd_adr
; write CharTo to new position
lda #CHAR+1
sta (zp),y
rts
!zone moveRight
moveRight ldx #7
ldy #8
.scroll_r ; shadow shifting (not visible)
lsr adrCharFromTmp,x
ror adrCharToTmp,x
dex
bpl .scroll_r
jsr wait
ldx #7
dey
bmi .end
; ORA partly shited shadow char with backgroung char
.ora lda adrCharToTmp,x
newBackgndAdr ora $1000,x
sta adrCharTo,x ; to position
lda adrCharFromTmp,x
oldBackgndAdr ora $1000,x
sta adrCharFrom,x ; from position
dex
bpl .ora
ldx #7
bne .scroll_r
.end ; restore the original char to old position
ldx oldypos
ldy oldxpos
lda oldbackgrnd
jsr printChar
; copy bytes adrCharTo -> adrCharFrom
ldx #7
.loop lda adrCharTo,x
sta adrCharFrom,x
dex
bpl .loop
; restore HiByte-adr to $1000
lda #$10
sta newBackgndAdr+2
sta oldBackgndAdr+2
sta backgnd_adr+2
rts
; # Y-coordinates to screen address
!zone table4xy
table4xy
lda screenLo,x
sta zp
sta zp2
lda #$1f
cpx #12
bpl .table4xy1
lda #$1e
.table4xy1 sta zp+1
clc
adc #120
sta zp2+1
rts
screenLo
!byte $00,$16,$2C,$42,$58,$6E,$84,$9A,$B0,$C6,$DC
!byte $F2,$8,$1E,$34,$4A,$60,$76,$8C,$A2,$B8,$CE,$E4
; # print char to xy
!zone printChar
printChar pha
jsr table4xy
pla
sta (zp),y
lda #6
sta (zp2),y
rts
; # W A I T
!zone wait
wait txa
pha
tya
pha
ldy #SPEED
.startx
ldx #$ff
.wait_loop
dex
bne .wait_loop
dey
bpl .startx
pla
tay
pla
tax
rts
; # I N I T
!zone init
init lda #$fc
sta $9005 ; char pointer to $1000
lda #147
jsr BSOUT ; clear screen
; copy characters to $1000
ldx #0
ldy #2
.loop lda $8000,x
.newchar sta $1000,x
dex
bne .loop
inc .loop+2
inc .newchar+2
dey
bne .loop
.restart ; ABCDE...T
ldy #0
sty xpos
ldx #10
stx ypos
.loopABC jsr table4xy
tya
jsr printChar
iny
cpy #21
bne .loopABC
lda #32
jsr printChar
; set ... values
lda #32
sta backgrnd
lda #$15
sta stepCount
rts
- moveRight
aitsch
- overlap.zip
- (519 Bytes) Downloaded 32 times
Have you had a look a the Software Sprite Stack by Robert Hurst that has been released on this forum in 2009?
http://sleepingelephant.com/ipw-web/bul ... php?t=3252
This was used for Berzerk MMX and Quikman by the same author which you can find in his repository as well:
https://github.com/theflyingape/
No need to re-invent the wheel
hi tokra,
thanks for your answer.
i'm programming in 6502-assembly for more or less 1 year. so i am a rookie in coding the vic.
i've heard from this sprite api but it is very complex and not so easy to understand.
for this api an ram extension of 8kb is recommended.
the level here is very high but i'm looking for the low hanging fruits, try to understand how the things work and what is possible with an standard vic-20 (unexpanded).
re-inverting the wheel was not my goal but comprehending what's going on.
that are the reasons why i've coded this example.
aitsch
aitsch
Works as supposed.aitsch wrote:what do you think about it?
Of course you will want to have all preparing steps done invisibly, i.e.:
- work out the position of the 'mini-bitmap' in the text screen,
- make a copy of the screen codes at that place,
- retrieve their background character definitions and write them to a pool of replacement character definitions,
- merge pattern definition into replacement character definitions.
- write screen codes of the replacement characters to text screen.
Note I did not specify how the pattern definition is supposed to be constructed. It may either be constructed/shifted on-the-fly as the merge procedure takes place, or get the data from a pool of pre-shifted definitions. The latter method is faster but needs more space.
Ideally, the change of screen codes should only happen when the raster beam is somewhere else.
That is alleviated a bit with multi-colour mode, at the expense of resolution. And you'll most probably want to use a masking technique, simply OR-ing in pattern data will not produce satisfactory results.the detriment is, that the background always need to have the same color like the moving character.
If the background scenery can get away with a somewhat less horizontal resolution (ho-hum) then doing inline splits of the background colour might be the weapon of choice, as seen in Victragic's implementation of Pitfall in 2013 ...
Other than that, as tokra already wrote, a sharp look at rhurst's Triple-S library is wholeheartedly recommended.
