Hi good afternoon.
I set the georam with 512kb in winvice.
I'm looking for a test program for the vic20 for the georam.
Thank you.
greeting
georam vic20 !!!
Re: georam vic20 !!!
Not sure I understand. xvic has a GeoRAM function?
Or, are you referring to Ultimem? xvic has an ultimem setting.
Ultimem would be far more useful than GeoRAM, as UltiMem allows 8kB RAM pages, not just 256 byte ones.
jim
jim
vice implements "MasC=uerade" (wasnt that one of your projects?), and via that allows to use georam (and a few other simple carts)
i dont think there is any software for this
Ah, yes, I didn't know that it did. Still, I think Ultimem will be a better option, as it offers you to fill all the VIC-20 RAM not just 256 bytes...
Jim
Jim
hello thanks for the info.
greeting
greeting
