TRSE : plot.....who can please implement this once?
Hi good afternoon.
who can do that for TRSE?
Thank you.
greeting
x=80
y=50
ad=4352
ay=int(y/16)*336+(y and 15)
ad=ad+16*int(x/8)+ay
ma=2^(7-(x and 7))
Thank you.
greeting
x=80
y=50
ad=4352
ma=2^(7-(x and 7))
trse can not do math
trse can not do math:
y,ay : integer;
y:=70;
ay:=y/16*336;
result : 1344
moveto(0,10,$10);
printdecimal(ay,4);
greeting
y,ay : integer;
y:=70;
ay:=y/16*336;
result : 1344
moveto(0,10,$10);
printdecimal(ay,4);
greeting
trse is weak in the graphics with PLOT, LINE, DRAW on the VIC20.
a few suggestions for the trse would be good so that you could tinker plot, line and draw.
trse has many secrets that are not known.
the math calculations are not exactly strong ih the trse
Could add something ....
Thank you.
Greeting
Thank you.
Greeting
when will there be a new version of trse ????
At the moment, trse still has a lot of shortcomings in operating comfort:
math (graphics) ... string ... disk ... The comfort must not only serve the c64 but also other systems.
the vic2o is still there ...
Version 0.09 (??.11.2019)......12.2019......01.2020 ???
you just make too many systems ...
that will not go well. everything is only halfway.
make few systems, then the quality is right.
greeting
greeting
- AndyH
- Occupation: Developer
Re: TRSE : plot.....who can please implement this once?
Nicolaas releases snapshot builds here: https://lemonspawn.com/turbo-rascal-syn ... downloads/
Thing to remember with TRSE it is a cross between a high level language and ASM and is in constant development. As such, you will not get all the comforts of a high level language and must think about the limitations of small 8-bit computers.
If you are ever unsure why something works as it does, create a small file with just the bit of code in you want to examine and build it. The ASM file produced will tell you what it is doing. This is especially useful for math operations. You may just need to try a different approach but as said, the ASM will reveal what it is doing.
I plan to release the Vic Bitmap Mode for TRSE next month.
Two points to note to the OP here:
1. It is not necessary to open four new threads which, in principle, highlight the same issue. I merged them into the single thread here.
2. For this kind of topics, Denial isn't exactly the right place to post. It is unlikely, that the maintainers of TRSE look here regularly. Please direct bug reports and feature requests to the appropriate FB group. Thanks.
- AndyH
This is a great place to log issues you find ... Github Issue log.
hello, good day.
tanks for the help.
greeting.
tanks for the help.
greeting.
trse : graphic mode of the vic20. but with the horizontal ones 2 are always left out a byte.
Hi good afternoon.
I can now set points in the graphic mode of the vic20.
a byte.
i don't find the error.
sys8192 is the start.
control with the buttons: WSAD
Thank you.
greeting
a byte.
Thank you.
greeting
program scrplot;
var
a,b,c,d,a1,ma,w,e,x,y :byte;
ad,ay,a2,a3,a4,a5,a6,a7:integer;
zpgrafscr: pointer;
zpchar: pointer;
zpy:pointer;
zpz:pointer;
zeroscr: pointer;
procedure plot();
begin
a1:=y/16;
a2:=a1*255;
a3:=a1*81;
a4:=a2+a3;
e:=y & 15;
a5:=a4+e;
a6:=(x/8)*16;
a7:=a5+a6;
end;
begin
zpgrafscr:=4352;
zpy:=4096-16;
zpz:=37888-16;
for b:=0 to 15 do
begin
for a:=0 to 255 do
begin
zpgrafscr[a]:=0;
end;
zpgrafscr:= zpgrafscr+255;
end;
poke(^36867,0,151);
poke(^36866,0,21);
poke(^36869,0,204);
poke(^36864,0,14);
for a:=16 to 255 do
begin
zpy[a]:=a;
zpz[a]:=6;
end;
x:=100;
y:=100;
plot();
zeroscr:=4352+a7;
ma:=2<<(7-(x & 7));
w:=zeroscr[0];
zeroscr[0]:=w | ma;
while (true) do
begin
waitforraster(0);
if peek(^197,0)= 17 then
begin
x:=x-1;
plot();
zeroscr:=4352+a7;
ma:=2<<(7-(x & 7));
w:=zeroscr[0];
zeroscr[0]:=w | ma;
end;
if peek(^197,0)= 18 then
begin
x:=x+1;
plot();
zeroscr:=4352+a7;
ma:=2<<(7-(x & 7));
w:=zeroscr[0];
zeroscr[0]:=w | ma;
end;
if peek(^197,0)= 41 then
begin
y:=y+1;
plot();
zeroscr:=4352+a7;
ma:=2<<(7-(x & 7));
w:=zeroscr[0];
zeroscr[0]:=w | ma;
end;
if peek(^197,0)= 9 then
begin
y:=y-1;
plot();
zeroscr:=4352+a7;
ma:=2<<(7-(x & 7));
w:=zeroscr[0];
zeroscr[0]:=w | ma;
end;
end;
end.
Re: trse : graphic mode of the vic20. but with the horizontal ones 2 are always left out a byte.
To the OP: once again, opening yet another thread for essentially the same issue doesn't improve things. It's much better to keep your progress in solving the problem in one single thread.
While we're being at it: "ma:=2<<(7-(x & 7));" is not the same as "MA = 2^(7 - (X AND 7))" (in BASIC). You can check this by printing out the results for X = 0..7 and compare.
hello, thanks.
why ist the : 2 ^ (7 - (X AND 7)) in the trse ?
greeting.
greeting.
(mod: ^^ double post removed)
In most modern programming languages the up arrow (^) acts as exclusive-or operator. It's really only BASIC, where the up arrow does an exponentiation operation. "<<" is the shift-left operator, and it's really not the value 2 you want to shift left here. Neither, for that matter, do you want to use such an expensive calculation to get the value for the bit supposed to be set. A table lookup is much more efficient.funkheld wrote:why ist the : 2 ^ (7 - (X AND 7)) in the trse ?
hello thanks.
i have make one mask : 1,2,4,8,16,32,64,128
this is ok.
greeting
this is ok.
greeting
Indeed, and if you fill the table with 128,64,32,16,8,4,2,1 you can index into the table with "[X&7]" instead of "[7-(X&7)]".funkheld wrote:i have make one mask : 1,2,4,8,16,32,64,128
hello, thanks
this is ok.
greeting.
this is ok.
greeting.
