hello, this "sta ($fb),y" not funktion in TRSE
funkheld
Post by funkheld »
procedure setchar();
begin
asm("
  lda #$00
  sta $fb
  lda  #$10
  sta $fc
  lda  #1
  ldy  #0
  sta ($fb),y
end;
greeting
Re: hello, this "sta ($fb),y" not funktion in TRSE
What you’ve written looks fine. I use that all the time in my bitmap code.
Are you sure $fb /fc is free to use ?
funkheld
Post by funkheld »
hello, no loop with dasm.
with orgasm loop.
greeting
You could try declaring a pointer which will use one of these ZP addresses:
$02, $04, $08, $16, $0B, $0D, $10, $12, $22, $24, $68 *** note these are defined in the TRSE project settings, so you can change them to your own requirements.
p1: pointer;
and in the code you could try something like
p1 := $1000;
asm("
  lda #1
  ldy #0
  sta (p1),y
or instead of the asm, p1[0] := 1;
That works for me.
Also, are you sure you have the screen at $1000 ?
funkheld
Post by funkheld »
hello, thanks.
yes, this is 4096.
greeting
