I would like to load the "test.p" program with the header "$1400"
funkheld
Post by funkheld »
Hi good afternoon.
it doesn't work.
what have I done wrong here?
Thank you.
greeting
!to "diskload.p", cbm
	*=8192
	setnam = $ffbd
	setlfs = $ffba
	open = $ffc0
	load = $ffd5
	lda #6
	ldx #<name
	ldy #>name
	jsr setnam
	lda #0
	ldy #8
	ldx #8
	jsr setlfs
	jsr open
	jsr load
	rts
name
  !text "TEST.P"
Re: I would like to load the "test.p" program with the header "$1400"
You don't want to call open, just setnam and setlfs. You should also set .A to zero otherwise the routine will perform a verify rather than a load.
funkheld
Post by funkheld »
hello thanks.
wonderfull , is ok.
greeting.
