Turbo Rascal - Vic Bitmap Mode
- AndyH
- Occupation: Developer
Re: Turbo Rascal - Vic Bitmap Mode
Working on the tutorial / example files now. It's a bit more interesting that all that test data I've been using during development.
- Vic 20 Devotee
- Website: http://davbucci.chez-alice.fr
Really cool effect, AndyH, I really like it!
fast and fluid
- AndyH
It looks great running at a true 50Hz, the GIF animation is not quite as fluid but quite close.
Here's the next one. So many ideas for games from doing these tutorial example files.
- joshuadenmark
- Big Mover
Wow that’s impressing.
Wonderful performance for the Vic20.
greeting
greeting
- AndyH
I'm still thinking up little example demo / tutorial files to include with Turbo Rascal to show some of the capabilities of the Vic 20 Bitmap Mode. This one is a bit scary, rated Vic 20.
It is silky smooth on the screen, my gif capture lags it a bit.
- AndyH
There is now a beta version available: Download zip
There is information in the help (F1) and some of the above demo files in the Vic 20 Tutorials folder. However, please be aware there will likely be bugs in this version. I am aware of an optimisation bug with ldx which you'll see some inline assembler in one of the files for example.
Hello, good evening.
it's nice to see something like this in the vic20.
a wonderful job of yours.
stay tuned to vic20 with your updates.
Thank you.
greeting
Thank you.
greeting
Hi good afternoon.
your trse with the sprite and the graphic
is super for the vic20.
I wrote a small sprite program here.
load"vbmsprite1.p",8,1
sys 8192
when the program is loaded and startet
you can load a picture with the "r" key
with the w/s/a/d buttons you can sprite move.
I found a little bug.
sometimes the sprite disappears
when moving and comes back when moving again.
this error occurs in several places,
but not always in the same place.
sometimes i don't believe the renewal of the sprite
comes with the movement and then bounces.
the picture is only loaded after address $a400 and
then moved to $1100.
sys 8192
program sprite;
var
i,a,b,x,y :byte;
zpg1:pointer;
zpg2:pointer;
spr8 : array[] of byte = (
%11111111,
%10000001,
%00111100,
%00100100,
%00100100,
%00111100,
%10000001,
%11111111
spr8L0 : array[8] of integer;
spr8R0 : array[8] of integer;
procedure load();
begin
asm("
lda b
ldx #<name
ldy #>name
jsr $ffbd
lda #0
ldy #8
ldx #8
jsr $ffba
lda #0
jsr $ffd5
end;
procedure text();
begin
poke(^36864,0,12);
poke(^36866,0,22);
poke(^36867,0,174);
poke(^36869,0,192);
ClearScreen(white, screen_col_loc);
poke(^214,0,0);
poke(^211,0,0);
call(^58640);
end;
procedure schiebe();
begin
zpg1:=4352;
zpg2:=$a400;
for b:=0 to 14 do
begin
for a:=0 to 255 do
begin
zpg1[a]:=zpg2[a];
end;
zpg1:=zpg1 + 255;
zpg2:=zpg2 + 255;
end;
zpg1:=4352+255*14;
zpg2:=$a400+255*14;
for a:=0 to 25 do
begin
zpg1[a]:=zpg2[a];
end;
end;
procedure laden();
begin
text();
b:=11;
load();
end;
begin
vbmSetDisplayMode( 0 );
vbmClear(0);
vbmClearColor(blue);
vbmSpriteShiftR( spr8, ^$a000, 1, 8, spr8L0 );
vbmSpriteShiftL( spr8, ^$a040, 1, 8, spr8R0 );
x:=80;
y:=90;
while (true) offpage do
begin
i := getkey();
case i of
KEY_d:
begin
x:=x+1;
if (x>150) then x:=150;
end;
KEY_a:
begin
x:=x-1;
if (x<2) then x:=2;
end;
KEY_s:
begin
y:=y+1;
if (y>184) then y:=184;
end;
KEY_w:
begin
y:=y-1;
if (y=255) then y:=0;
end;
KEY_r:
begin
text();
laden();
vbmClear(0);
schiebe();
end;
end;
vbmSetPosition1( x, y );
vbmDrawSprite8e( spr8L0, spr8R0 );
waitforraster( 0 );
end;
end.
- spritebug.jpg (12.33 KiB) Viewed 2213 times
- disk1.zip
- (1.75 KiB) Downloaded 62 times
- AndyH
Great!
Are you able to replicate that sprite problem in a smaller example file with just the sprite?
hello,
that will probably be because of the picture and
not on your sprite routine.
your trse is fine
greeting
your trse is fine
greeting
Hi good afternoon.
the fuel block only works on the left
when the whole sprite is on the ground.
the fuel block works correctly on the right up to the last point
of the ground.
how do I have to set this correctly on the left?
greeting
of the ground.
greeting
program sprite;
var
i,a,b,x,y :byte;
zpg1:pointer;
zpg2:pointer;
%11111111,
%10000001,
%00111100,
%00100100,
%00100100,
%00111100,
%10000001,
%11111111
begin
vbmClear(0);
for b:=0 to 20 do
begin
vbmDrawblot( b,20 );
end;
for b:=50 to 80 do
begin
vbmDrawblot( b,60 );
end;
for b:=120 to 150 do
begin
vbmDrawblot( b,80 );
end;
for b:=0 to 80 do
begin
vbmDrawblot( b,100 );
end;
for b:=100 to 159 do
begin
end;
for b:=0 to 159 do
begin
vbmDrawblot( b,180 );
end;
x:=50;
y:=20;
begin
i := getkey();
case i of
KEY_d:
begin
x:=x+1;
if (x>152) then x:=152;
end;
KEY_a:
begin
x:=x-1;
if (x=255) then x:=0;
end;
KEY_s:
begin
y:=y+1;
end;
KEY_w:
begin
y:=y-1;
end;
KEY_r:
begin
end;
end;
waitforraster( 0 );
if (vbmTestPixel2( x, y+8 ) = 0) then
begin
y := y + 1;
end;
if (vbmTestPixel2( x, y-2 ) = 0) then
begin
y := y - 1;
end;
end;
end.
- ok-right.jpg (2.85 KiB) Viewed 2183 times
- not-ok-left.jpg (2.19 KiB) Viewed 2183 times
- ok-left.jpg (2.29 KiB) Viewed 2183 times
- AndyH
vbmDrawSprite8e Draws with an eor operation. It’s good because it won’t destroy other pixels on the bitmap. However, when it goes over pixels you will see that result.
You can use vbmDrawSprite8 and vbmClearSprite8 instead but this will erase the bitmap so you would need to restore the line after.
Hello thanks for the information.
asm(" ldx #152;keep");
vbmScreenShiftright( 50, 191 );
why is : asm(" ldx #152;keep");
greeting
greeting
