trse : a sprite 8 byte and a sprite 16 byte in the whole top row.
funkheld
Post by funkheld »
a sprite 8 byte in the whole top row right and left and a sprite 16 byte in the whole top row.
control with the keys A / D.
vic20 8 + kb.
greeting
sprite 16byte:
program srite;
var
charset : array[8] of byte = ( 24,24,60,126,255,24,36,66,255,129,129,129,129,129,129,255);
a, b : byte;
zpcharz: pointer;
zpchars: pointer;
zpscr: pointer;
zpcol: pointer;
procedure shiftre();
begin
	asm("
	 	ldx #0
Rightshift
	lda $1400,x
	lsr
	ror $1400+16 ,x
	ror $1400+32 ,x
	ror $1400+48 ,x
	ror $1400+64 ,x
	ror $1400+80 ,x
	ror $1400+96 ,x
	ror $1400+112 ,x
	ror $1400+128 ,x
	ror $1400+144 ,x
	ror $1400+160 ,x
	ror $1400+176 ,x
	ror $1400+192 ,x
	ror $1400+208 ,x
	ror $1400+224 ,x
	ror $1400+240 ,x
	ror $1400+256 ,x
	ror $1400+272 ,x
	ror $1400+288 ,x
	ror $1400+304 ,x
	ror $1400+320 ,x
	ror $1400+336 ,x
	ror $1400,x
	inx
	cpx #16
	bne Rightshift
end;
procedure shiftli();
begin
	asm("
	ldx #0
leftshift
	lda $1400,x
	lda $1400,x
	asl
	rol $1400+336 ,x
	rol $1400+320 ,x
	rol $1400+304 ,x
	rol $1400+288 ,x
	rol $1400+272 ,x
	rol $1400+256 ,x
	rol $1400+240 ,x
	rol $1400+224 ,x
	rol $1400+208 ,x
	rol $1400+192 ,x
	rol $1400+176 ,x
	rol $1400+160 ,x
	rol $1400+144 ,x
	rol $1400+128 ,x
	rol $1400+112 ,x
	rol $1400+96 ,x
	rol $1400+80 ,x
	rol $1400+64 ,x
	rol $1400+48 ,x
	rol $1400+32 ,x
	rol $1400+16 ,x
	rol $1400,x
	inx
	cpx #16
	bne leftshift
end;
begin
  ClearScreen(white, screen_col_loc);
  zpcharz:=5120;
  zpchars:=32768;
  zpscr:=4096;
  zpcol:=37888;
  poke(^37139,0,0);
  poke(^37154,0,127);
  poke(^36869,0,205);
  poke(^36867,0,151);
  for b:=0 to 8 do
	begin
		for a:=0 to 255 do
		begin
    	zpcharz[a]:=0;
    end;
    zpcharz:= zpcharz+255;
  end;
  zpcharz:=5120;
	for b:=0 to 16 do
	begin
		zpcharz[b]:=charset[b];
	end;
  zpscr:=4096;
  for b:=0 to 22 do
	begin
		zpscr[b]:=b;
	end;
  zpcol:=37888;
	for b:=0 to 22 do
	begin
		zpcol[b]:=4;
	end;
  while (true) do
	begin
	  waitforraster(0);
	  if peek(^197,0)= 17 then
    begin
    shiftli();
    end;
    if peek(^197,0)= 18 then
    begin
     shiftre();
    end;
  end;
end.
sprite 8byte :
program sprite;
var
charset : array[8] of byte = (24,24,60,126,255,24,36,66);
a, b : byte;
zpcharz: pointer;
zpchars: pointer;
zpscr: pointer;
zpcol: pointer;
begin
	asm("
	ldx #0
Rightshift
	lda $1400,x
	lsr
	ror $1400+8 ,x
	ror $1400+16 ,x
	ror $1400+24 ,x
	ror $1400+32 ,x
	ror $1400+40 ,x
	ror $1400+48 ,x
	ror $1400+56 ,x
	ror $1400+64 ,x
	ror $1400+72 ,x
	ror $1400+80 ,x
	ror $1400+88 ,x
	ror $1400+96 ,x
	ror $1400+104 ,x
	ror $1400+112 ,x
	ror $1400+120 ,x
	ror $1400+128 ,x
	ror $1400+136 ,x
	ror $1400+144 ,x
	ror $1400+152 ,x
	ror $1400+160 ,x
	ror $1400+168 ,x
	ror $1400,x
	inx
	cpx #8
	bne Rightshift
end;
begin
	asm("
	ldx #0
leftshift
	lda $1400,x
	lda $1400,x
	asl
	rol $1400+168 ,x
	rol $1400+160 ,x
	rol $1400+152 ,x
	rol $1400+144 ,x
	rol $1400+136 ,x
	rol $1400+128 ,x
	rol $1400+120 ,x
	rol $1400+112 ,x
	rol $1400+104 ,x
	rol $1400+96 ,x
	rol $1400+88 ,x
	rol $1400+80 ,x
	rol $1400+72 ,x
	rol $1400+64 ,x
	rol $1400+56 ,x
	rol $1400+48 ,x
	rol $1400+40 ,x
	rol $1400+32 ,x
	rol $1400+24 ,x
	rol $1400+16 ,x
	rol $1400+8 ,x
	rol $1400,x
	inx
	cpx #8
	bne leftshift
end;
begin
  zpcharz:=5120;
  zpchars:=32768;
  zpscr:=4096;
  zpcol:=37888;
  poke(^37139,0,0);
  poke(^37154,0,127);
  poke(^36869,0,205);
  for b:=0 to 8 do
	begin
		for a:=0 to 255 do
		begin
    	zpcharz[a]:=0;
    end;
  end;
  zpcharz:=5120;
	for b:=0 to 8 do
	begin
	end;
  zpscr:=4096;
  for b:=0 to 22 do
	begin
		zpscr[b]:=b;
	end;
  zpcol:=37888;
	for b:=0 to 22 do
	begin
		zpcol[b]:=4;
	end;
  while (true) do
	begin
	  waitforraster(0);
    begin
    shiftli();
    end;
    begin
     shiftre();
    end;
  end;
end.
funkheld
Re: trse : a sprite 8 byte and a sprite 16 byte in the whole top row.
Post by funkheld »
here sprite in the first row for the graphic mode from address 4352
it's easy you just need to change the addresses.
and a char less in the row.
greeting
program shiftgraf;
var
charset : array[16] of byte = (24,24,60,126,255,24,36,66,255,129,129,129,129,129,129,255);
a, b: byte;
zpgrafscr: pointer;
zpchar: pointer;
zpy:pointer;
zpz:pointer;
begin
	asm("
	ldx #0
Rightshift
	lda 4352,x
	lsr
	ror 4352+16 ,x
	ror 4352+32 ,x
	ror 4352+48 ,x
	ror 4352+64 ,x
	ror 4352+80 ,x
	ror 4352+96 ,x
	ror 4352+112 ,x
	ror 4352+128 ,x
	ror 4352+144 ,x
	ror 4352+160 ,x
	ror 4352+176 ,x
	ror 4352+192 ,x
	ror 4352+208 ,x
	ror 4352+224 ,x
	ror 4352+240 ,x
	ror 4352+256 ,x
	ror 4352+272 ,x
	ror 4352+288 ,x
	ror 4352+304 ,x
	ror 4352+320 ,x
	ror 4352,x
	inx
	cpx #16
	bne Rightshift
end;
begin
	asm("
	ldx #0
leftshift
	lda 4352,x
	lda 4352,x
	asl
	rol 4352+320 ,x
	rol 4352+304 ,x
	rol 4352+288 ,x
	rol 4352+272 ,x
	rol 4352+256 ,x
	rol 4352+240 ,x
	rol 4352+224 ,x
	rol 4352+208 ,x
	rol 4352+192 ,x
	rol 4352+176 ,x
	rol 4352+160 ,x
	rol 4352+144 ,x
	rol 4352+128 ,x
	rol 4352+112 ,x
	rol 4352+96 ,x
	rol 4352+80 ,x
	rol 4352+64 ,x
	rol 4352+48 ,x
	rol 4352+32 ,x
	rol 4352+16 ,x
	rol 4352,x
	inx
	cpx #16
	bne leftshift
end;
begin
  zpgrafscr:=4352;
  zpy:=4096-16;
  zpz:=37888-16;
  for b:=0 to 15 do
	begin
		for a:=0 to 255 do
		begin
    	zpgrafscr[a]:=0;
    end;
    zpgrafscr:= zpgrafscr+255;
  end;
  poke(^36867,0,151);
  poke(^36866,0,21);
  poke(^36869,0,204);
  poke(^36864,0,14);
  for a:=16 to 255 do
  begin
    zpy[a]:=a;
    zpz[a]:=6;
  end;
  zpchar:=4352;
	for a:=0 to 16 do
	begin
		zpchar[a]:=charset[a];
	end;
  while (true) do
	begin
	  waitforraster(0);
    begin
	    shiftli();
    end;
    begin
	    shiftre();
    end;
  end;
end.
funkheld
Post by funkheld »
I have now in the graphic mode 2 sprite on top of each other.
the top row with Q / E and the 2nd row control with A / D.
the size of the prg is so small at trse that you can fill 10 lines and each line is then controlled.
if you join the rows, by switching you can create a sprite move.
maybe one of you will find a vertical movement for that.
start with sys8192.
the prg has 570 bytes, if you can move 2 rows.
So trse is wonderfully economical.
you can easily make 10 rows and has a movement on the whole screen.
greeting
program shiftgraf;
var
a, b: byte;
zpgrafscr: pointer;
zpchar: pointer;
zpy:pointer;
zpz:pointer;
begin
	asm("
	ldx #0
Rightshift
	lda 4352,x
	lsr
	ror 4352+16 ,x
	ror 4352+32 ,x
	ror 4352+48 ,x
	ror 4352+64 ,x
	ror 4352+80 ,x
	ror 4352+96 ,x
	ror 4352+112 ,x
	ror 4352+128 ,x
	ror 4352+144 ,x
	ror 4352+160 ,x
	ror 4352+176 ,x
	ror 4352+192 ,x
	ror 4352+208 ,x
	ror 4352+224 ,x
	ror 4352+240 ,x
	ror 4352+256 ,x
	ror 4352+272 ,x
	ror 4352+288 ,x
	ror 4352+304 ,x
	ror 4352+320 ,x
	ror 4352,x
	inx
	cpx #16
	bne Rightshift
end;
begin
	asm("
	ldx #0
leftshift
	lda 4352,x
	lda 4352,x
	asl
	rol 4352+320 ,x
	rol 4352+304 ,x
	rol 4352+288 ,x
	rol 4352+272 ,x
	rol 4352+256 ,x
	rol 4352+240 ,x
	rol 4352+224 ,x
	rol 4352+208 ,x
	rol 4352+192 ,x
	rol 4352+176 ,x
	rol 4352+160 ,x
	rol 4352+144 ,x
	rol 4352+128 ,x
	rol 4352+112 ,x
	rol 4352+96 ,x
	rol 4352+80 ,x
	rol 4352+64 ,x
	rol 4352+48 ,x
	rol 4352+32 ,x
	rol 4352+16 ,x
	rol 4352,x
	inx
	cpx #16
	bne leftshift
end;
procedure shiftre1();
begin
	asm("
	ldx #0
Rightshift1
	lda 4352+336,x
	lsr
	ror 4352+16 +336,x
	ror 4352+32 +336,x
	ror 4352+48 +336,x
	ror 4352+64 +336,x
	ror 4352+80 +336,x
	ror 4352+96 +336,x
	ror 4352+112 +336,x
	ror 4352+128 +336,x
	ror 4352+144 +336,x
	ror 4352+160 +336,x
	ror 4352+176 +336,x
	ror 4352+192 +336,x
	ror 4352+208 +336,x
	ror 4352+224 +336,x
	ror 4352+240 +336,x
	ror 4352+256 +336,x
	ror 4352+272 +336,x
	ror 4352+288 +336,x
	ror 4352+304 +336,x
	ror 4352+320 +336,x
	ror 4352+336,x
	inx
	cpx #16
	bne Rightshift1
end;
procedure shiftli1();
begin
	asm("
	ldx #0
leftshift1
	lda 4352+336,x
	lda 4352+336,x
	asl
	rol 4352+320 +336,x
	rol 4352+304 +336,x
	rol 4352+288 +336,x
	rol 4352+272 +336,x
	rol 4352+256 +336,x
	rol 4352+240 +336,x
	rol 4352+224 +336,x
	rol 4352+208 +336,x
	rol 4352+192 +336,x
	rol 4352+176 +336,x
	rol 4352+160 +336,x
	rol 4352+144 +336,x
	rol 4352+128 +336,x
	rol 4352+112 +336,x
	rol 4352+96 +336,x
	rol 4352+80 +336,x
	rol 4352+64 +336,x
	rol 4352+48 +336,x
	rol 4352+32 +336,x
	rol 4352+16 +336,x
	rol 4352+336,x
	inx
	cpx #16
	bne leftshift1
end;
begin
  zpgrafscr:=4352;
  zpy:=4096-16;
  zpz:=37888-16;
  for b:=0 to 15 do
	begin
		for a:=0 to 255 do
		begin
    	zpgrafscr[a]:=0;
    end;
  end;
  poke(^36867,0,151);
  poke(^36866,0,21);
  poke(^36869,0,204);
  poke(^36864,0,14);
  for a:=16 to 255 do
  begin
    zpy[a]:=a;
    zpz[a]:=6;
  end;
  zpchar:=4352;
	for a:=0 to 16 do
	begin
	end;
  zpchar:=4352+336;
	for a:=0 to 16 do
	begin
	end;
  while (true) do
	begin
	  waitforraster(0);
    begin
	    shiftli();
    end;
    begin
	    shiftre();
    end;
   if peek(^197,0)= 48 then
     begin
	    shiftli1();
     end;
   if peek(^197,0)= 49 then
    begin
	    shiftre1();
    end;
  end;
end.
Nice :)
Looks like you are really enjoying TRSE.
