Listing to be fixed
saver71
Website: https://superottanta.blogspot.com
Occupation: Advertiser
Listing to be fixed
Post by saver71 »
Hello to all.
I have typed a listing from an Italian magazine, but I find a problem: the joystick does not move the little man.
I point out that the listing is correct, checked several times. I also checked the original version of Compute!'s Gazette magazine, and it's all right.
Can you help me?
I attach the PRG and TXT files.
Thanks in advance.
il_tesoro_perduto.rar
(5.84 KiB) Downloaded 100 times
DarwinNE
Re: Listing to be fixed
Post by DarwinNE »
Hi!
Can you please post an image of the original listing (readable)?
However, it was not uncommon that type-ins programs of the era contained typos, if you checked against the listing, did you see if there is an erratum published afterwards?
vicist
Post by vicist »
Change the 7 at the end of line 6040 to 73 and it will then work properly. :)
saver71
Post by saver71 »
Perfect! Here's the bug!
It was a typo in the magazine, as can be seen in the attached file.
Thanks so much to both of you. :wink:
