data transfer rs232 with vic20.
i have notebook with win10.
I have:
- tera term
- Setup VSPE
- vice
vice set up for the rs232 :
\\.\com1: baud=300 parity=N data=8 stop=1
with setupvspe I have set up a virtual rs232 com1.
I transfer the data with tera term.
You can also transfer data to the pc with an arduino.
greeting
this demo:
10 print "opening port..."
11 open 1,2,0,chr$(10)
12 gosub 1000: if ec <> 0 then close 1:end
15 print "type your message:"
20 for i = 0 to 2
30 input m$
40 print#1, m$ + str$(i) + chr$(13) + chr$(10)
50 gosub 1000
55 next i
60 print "waiting for reply..."
70 get #1, a$: ec = st: if ec = 8 then goto 70
80 if ec <> 0 then print "error:";ec
100 if a$ <> "" then print a$;
105 goto 70
1000 ec = st
1001 if ec > 0 then print "error:";ec
1010 return
- SetupVSPE.zip
- (3.02 MiB) Downloaded 87 times
Re: data transfer rs232 with vic20.
tera term is to big for the forum.
teraterm-4.96.exe
greeting
teraterm-4.96.exe
greeting
hello, with the arduino it works too.
then you do not need the virtual port on the pc.
greeting
greeting
