Forum is back
Re: Forum is back
Bah, when I try a substantial edit it still fails.
- highinfidelity
- Vic 20 Nerd
Re: Forum is back
My avatar is no longer shown, although still visible in my profile. I suppose this happens because the limit is set to 80 pixels only. I think it was 100 pixels before "the big issue", as I remember tailoring my avatar specifically for this forum. Is it possible to revert the upper limit to 100 pixels? (Or perhaps even more than that, at your will, considered that the average size of the screens has increased a lot over the years?)
- joshuadenmark
- Big Mover
Re: Forum is back
Donehighinfidelity wrote: ↑Fri Nov 08, 2019 2:06 am My avatar is no longer shown, although still visible in my profile. I suppose this happens because the limit is set to 80 pixels only. I think it was 100 pixels before "the big issue", as I remember tailoring my avatar specifically for this forum. Is it possible to revert the upper limit to 100 pixels? (Or perhaps even more than that, at your will, considered that the average size of the screens has increased a lot over the years?)
- joshuadenmark
- Big Mover
Re: Forum is back
Thats bad, will look into this.
- highinfidelity
- Vic 20 Nerd
Re: Forum is back
Thanks a lot, mate!joshuadenmark wrote: ↑Fri Nov 08, 2019 2:12 amDonehighinfidelity wrote: ↑Fri Nov 08, 2019 2:06 am My avatar is no longer shown, although still visible in my profile. I suppose this happens because the limit is set to 80 pixels only. I think it was 100 pixels before "the big issue", as I remember tailoring my avatar specifically for this forum. Is it possible to revert the upper limit to 100 pixels? (Or perhaps even more than that, at your will, considered that the average size of the screens has increased a lot over the years?)
- highinfidelity
- Vic 20 Nerd
Re: Forum is back
Er... how is it that I seem to see a smiley taken from a different set in your post?
Re: Forum is back
I still can't see High's avatar.
Re: Forum is back
Did this get looked at? I still can't make big changes to wiki articles.
- joshuadenmark
- Big Mover
Re: Forum is back
Yes - didn't get errors. Can you provide a screenshot of the fail?
Re: Forum is back
joshuadenmark wrote: ↑Sat Feb 29, 2020 2:39 am Yes - didn't get errors. Can you provide a screenshot of the fail?
- joshuadenmark
- Big Mover
Re: Forum is back
It looks like a theme is missing... will try to install this and will reply later, thanks
Can I get you to choose another skin here, if you can get this far:
http://sleepingelephant.com/denial/wiki ... -rendering
Re: Forum is back
Sorry, didn't see your update.
I already set the MonoBook skin last time I had problems. I'll try the others.
Re: Forum is back
Hi, Peter,
one other question: the underline of URL markers has too big a spacing. Sometimes, when a link is show within a bigger paragraph, the underline actually seems to "overline" words of the following line. Is that spacing a setting that could be reduced in the CSS?
Please compare the pixel spacing between a normal underline and an URL link to see what I mean. And also how the URL underline encroaches upon the following text line: Lorem ipsum dolor sit amet, consectetur adipisici elit, sed eiusmod tempor incidunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquid ex ea commodi consequat. Quis aute iure reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint obcaecat cupiditat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
Re: Forum is back
I've tried all three skins, still behaves the same.
Re: Forum is back
If you locate this file:srowe wrote: ↑Tue Mar 10, 2020 1:25 pmI've tried all three skins, still behaves the same.Mike wrote:one other question: the underline of URL markers has too big a spacing. Sometimes, when a link is show within a bigger paragraph, the underline actually seems to "overline" words of the following line. Is that spacing a setting that could be reduced in the CSS?
ipw-web/bulletin/bb/styles/prosilver/theme/links.css
and find this block around line 103:
/* Post body links */
.postlink {
text-decoration: none;
border-bottom: 1px solid transparent;
padding-bottom: 0;
.postlink {
text-decoration: underline;
border-bottom: none;
padding-bottom: 0;
