Emulation of RS232 VIC20 for running multiplayer games
MartinC
Website: https://winterfam.co.uk
Occupation: Author
Re: Emulation of RS232 VIC20 for running multiplayer games
Post by MartinC »
mimmosic wrote: Fri Jul 05, 2019 9:10 am Building the connection cable is easy.
1. get a normal stereo audio cable (two lines plus the ground) and two connectors for the RS232 port.
2. Mark each connector with a label "TOP SIDE" just to avoid confusion later
3. Solder the ground of the cable to the A pin of both connectors.
4. Connector 1: Solder pins B and C together to red cable, Solder pin M to white cable
5. Connector 2, do the opposite: Solder pins B and C together to WHITE cable, Solder pin M to RED cable
Connect to VICs, turn them on, test.
Below the schematics of the VICs user port. Pins B and C are CB1/PB0 (input), M pins is CB2 (output)
Next, I'll be posting the photos of my cable's finished connectors. I tested the above with a 50m+ cable and worked great.
After seeing it working on real VICs, you will want to test it on emulators like I do!
Now that I have 2 working Vics I am going to try the above User port cable build out. Is the wiring schema above correct and safe?
Why are pins B and C jumpered? Is it so that an interrupt is raised when data is received along PB0?
I haven't looked at mimmosic's code yet, but I'm guessing that CB2 will be set to HANDSHAKE OUTPUT MODE for this to work?
I have a cable with four cores, do I need pin N as a second ground connection? Does it matter if I connect both ground pins?
I'm going to use some spade terminals on the User port edge connector pins to make the cable re-configurable to start with.
Thanks in advance for your kind responses.
MartinC wrote: Wed Feb 21, 2024 9:21 am Why are pins B and C jumpered? Is it so that an interrupt is raised when data is received along PB0?
Correct, the receive line must be connected to both CB1 and PB0 so that a interrupt is generated on a start bit and the data value can be read for the actual bit. Handshaking on VIA ports is only relevant for parallel communications, the KERNAL RS-232 routines just bit bang the Tx/Rx lines.
MartinC
Occupation: Author
Post by MartinC »
Ok, well, I built my cable last weekend, so I'll do some more reading and give this a try.
mimmosic
Website: https://vic20reloaded.com
Occupation: programmer
Post by mimmosic »
Hello,
I am happy that you decided to give the cable a try.
I have used the cable for a long time. My VIC and a friend of mine's stayed connected for a couple of years with a 50 meters-long cable running from one building to another.
Check out the "Networking VIC" diskette with the three software
Happylink (chat software)
Ship Battle (game)
Horse Racing (game)
I remember how these simple games were big fun at that time!
Orangeman96
Post by Orangeman96 »
Is it fair to say this cable is essentially a null modem cable? (We used to use such cables to play F-15E Strike Eagle III in two-player mode: with one 80486 rig as the pilot, and the other 80486 rig as the "guy-in-back" -- officially, the Weapons Systems Officer.) -OGM
