(Ultimem) expansion RAM cleared on hard reset?
- pixel
- Website: http://hugbox.org/
My stuff's in storage, so I cannot check myself.
Re: (Ultimem) expansion RAM cleared on hard reset?
Not on its own. I'd guess at least.
What happens in VICE is probably another matter. Ctrl-R performs a reset but keeps RAM contents - internal, normal RAM expansion, and presumably of banked RAM expansions as well -, Shift-Ctrl-R clears the RAM, better said, applies the RAM init pattern to BLK0..BLK3 but fills BLK5 with all zeroes.
On real hardware, you'd need a routine in firmware to clear the banked RAM, as the KERNAL of course knows nothing about Ultimem. Also, the KERNAL only initialises pages 0, 2 and 3 upon power on/reset and doesn't touch other RAM, i.e. the RAM test performed is non-destructive.
You're concerned the contents of a RAM disk on Ultimem (hopefully) survive a reset?
- pixel
That would be lovely. And it's key to the fast restore on reset. Want "Ingle" to jump right back to where it was.Mike wrote:You're concerned the contents of a RAM disk on Ultimem (hopefully) survive a reset?
Cannot work on that game at the moment but wanna nail something down anyway. Am starting a new job next week, so even I should get an own place to live here in Berlin again.
- pixel
Oh, well, and multi-processing. Not multi-tasking.
And thanks for your help, btw.
Sorry for the delay. RAM is not reset on reset.
Jim
Jim
The RAM in 32k/35k Ultimate Expanders I have sold in the past is also not cleared on reset.
Some of them used Cypress SRAM ICs which had trickle power mode. If you had a 1541 disk drive attached to the IEC port, the trickle amount of power flowing back in the VIC-20 through the reset line would be enough to keep the content of the SRAM intact even when turning the VIC-20 off.
- pixel
Hey, that's great! Thanks! Works out pretty well. Returns to the GUI within a blink of an eye. Will show off later.
