Noise generator implementation in VICE
nippur72
de Lagash
Post by nippur72 »
This thread forked from 6561 Die Shot Reversing Explorations
@gropaz: this is my first attempt (I haven't tried to compile it yet). Replace the lines ranging from 318-365 with the code below.
Previously the voice j=3 was handled separately, now it's a special case of the more generic sound generation. I leaved the LFSR feedback formula unoptimized for better understanding, I hope I have transcribed it correctly.
I've also have compressed the "if enabled ... else ..." statement into a single case by making an "& enabled";
Note also that sound generation doesn't take into account the DC offset as discussed in this thread (my TODO comment at the bottom)
    // new noise generator as found by Lance Ewing
    unsigned short noise_LFSR; // 16 bit static variable
    for (j = 0; j < 4; j++) {   // extended to 4 voices
        int chspeed = "\4\3\2\1"[j];  // added 4th speed
        if (snd.ch[j].ctr > cycles) {
            snd.accum += snd.ch[j].out * cycles;
            snd.ch[j].ctr -= cycles;
        } else {
            for (i = cycles; i; i--) {
                snd.ch[j].ctr--;
                if (snd.ch[j].ctr <= 0) {
                    int a = (~snd.ch[j].reg) & 127;
                    a = a ? a : 128;
                    snd.ch[j].ctr += a << chspeed;
                    int enabled = (snd.ch[j].reg & 128) >> 7;
                     // if it's a normal voice or it's noise and LFSR out is 1
                     if(j !== 3 || (j==3 && (noise_LFSR & 1)) {
                        unsigned char shift = snd.ch[j].shift;
                        shift = ((shift << 1) | ((((shift & 128) >> 7)) ^ 1) & enabled));
                        snd.ch[j].shift = shift;
                        if(j==3) {
                           int bit3  = ((noise_LFSR & 1<< 3)>> 3);
                           int bit12 = ((noise_LFSR & 1<<12)>>12);
                           int bit14 = ((noise_LFSR & 1<<14)>>14);
                           int bit15 = ((noise_LFSR & 1<<15)>>15);
                           int gate1 = bit3 ^ bit12;
                           int gate2 = bit14 ^ bit15;
                           int gate3 = ~(gate1 ^ gate2);
                           int gate4 = ~(gate3 & enabled);
                           noise_LFSR = (noise_LFSR << 1) | gate4;
                     snd.ch[j].out = snd.ch[j].shift & 1;
                snd.accum += snd.ch[j].out;  // <= TODO doesn't take into accound DC offset
If you try it, I am curious whether it works or not. You can test it by POKEing 36877, 254, a quickly repeating humming pattern should be heard.
Re: Noise generator implementation in VICE
i reworked the code a bit, now it does work as far as i can tell:
/* FIXME: what is the init value? what happens on reset? */
static uint16_t noise_LFSR = 0xffff;
void vic_sound_clock(int cycles)
    int i, j, enabled;
    if (cycles <= 0) {
        return;
        } else {
                snd.ch[j].ctr--;
                    a = a ? a : 128;
                     /* if it's a normal voice or it's noise and LFSR out is 1 */
                    if((j != 3) || ((j == 3) && (noise_LFSR & 1))) {
                        uint8_t shift = snd.ch[j].shift;
                        shift = ((shift << 1) | ((((shift & 128) >> 7)) ^ 1) & enabled);
                    if(j == 3) {
                        int bit3  = (noise_LFSR >> 3) & 1;
                        int bit12 = (noise_LFSR >> 12) & 1;
                        int bit14 = (noise_LFSR >> 14) & 1;
                        int bit15 = (noise_LFSR >> 15) & 1;
                        int gate3 = (gate1 ^ gate2) ^ 1;
                        int gate4 = (gate3 & enabled) ^ 1;
                snd.accum += snd.ch[j].out; /* FIXME: doesn't take DC offset into account */
    snd.accum_cycles += cycles;
POKE 36878,15 is required first to make any sound, is that the same on the real thing?
then POKE 36877,254 gives me a very light high frequency noise... but 255 creates a rather harsh growling sound. does that sound legit? :)
PS: still some sort of testcase would be nice, so i can verify its not completely bolloks before checking it in :)
nippur72
de Lagash
Post by nippur72 »
can you share your build workflow? If it's not too complex I would like to compile it and compare to my FPGA and real VIC. Is linux needed?
The "noise_LFSR" variable doesn't need to be initialized. As found by Lance on the other thread, the register will init by itself after a number of cycles thanks to the "& enabled" in the "int gate4 = (gate3 & enabled) ^ 1;" which puts a "1" in the LFSR even if it is all "0"s. I guess this is a trick they used to spare the load/init circuit.
yes, it is (it puts the volume to maximum).
yes, it think it's a quirk in the design of the circuit. They first increment and then check for overflow, so when the value is 127 (bit7 not counted) it gets incremented so it wraps down to 0 and you get a low frequency.
that's not easy at all. Perhaps sampling and comparing the FFT spectrums? Or more simply compare vs a real vic?
yes and no :) remember that with VICE we are aiming for an autistic level of accuracy - the first couple bits the LFSR produces will be different depending on the init value :) (it doesnt matter in practise, no). my guess would be its all 1s after a powercycle (because that what seems to happen in most cases with NMOS). if there is no reset circuit for it, then the current code should be accurate :)
the easiest way to build vice right now is to use linux - but you can do it on windows too (osx is a bit broken atm). for windows there are instructions here: https://sourceforge.net/p/vice-emu/code ... -Howto.txt
nippur72
de Lagash
Post by nippur72 »
yes I guess 0xFFFF is a good initialization value.
As for building it -- I'm too lazy to setup the whole build chain, can you send me the resulting xvic.exe? (my email: nino.porcino@gmail.com)
i uploaded a testbuild here: http://hitmen.c02.at/temp/GTK3VICE-3.3-win64-r36240.zip (untested, i use linux)
nippur72
de Lagash
Post by nippur72 »
sorry, the .exe do not work (the only one working is x64dtv.exe). A small empty window opens and then closes. But nothing else happens.
darn, guess thats why i am not building regular windows binaries =D
i have comitted the change to trunk now, you can probably grab a binary from retroplay in a day or two here: https://mega.nz/#F!HklwlAZS!vDiSevLlzGQUQL6wOmvhUg (the change is in r36241)
Windows 10 has a Linux subsystem now..perhaps this can be used?
perhaps, feel free to try :)
the above link has updated windows builds now... those should work
nippur72
de Lagash
Post by nippur72 »
I've tested it right now -- it sounds good to me!
Anyone else want to try it? we need more opinions. Until we find a more rigorous way to test it.
anyone? :)
nippur72
de Lagash
Post by nippur72 »
what about if we sample the audio during POKE 36877,X at a reasonable high sample rate (e.g. 44100 x 2) and then convert it back to a square wave? I think we should be able to see the same "print" of the emulated sound.
Two problems to solve:
1) choose "X" so that the resulting sound is in the middle of the bandwidth of the audio filters (LP 16Khz + LP 1.6Khz + HP 160 HZ)
2) compensate any small clock difference between VICE and the real VIC20.
Does VICE lets you capture audio in .WAV ?
sure, you can capture sound from VICE
tlr
Post by tlr »
The tricky thing about the noise generator in the VIC-I is that it doesn't generate the same noise shape every time. It seems to randomly start generating noise with a different frequency content for a while, then switching back. There were claims that this had to do with the timing of turning of the previous sound/noise but any detailed description failed to surface.
