So I tried out a one line random noise generator program based off one I know about for the C64. Goes like so:
10 POKE 36874+RND(1)*25,RND(1)*256 : GOTO 10
But when I run this the VIC-20 (right now just an emulator for experimenting, I should say) the screen explodes into random color madness, and while this is delightful, I would like a certain degree of control over it. How would I prevent this? Also, if I didn't want to prevent this, how would I be able to stop it and get back to programming? When the ball gets rolling on the above program and I hit STOP it leaves the screen as a blob of color and characters.
Thanks!
Random Noise Generator
- Kweepa
- Occupation: Game maker
Re: Random Noise Generator
Well, geez, you are poking garbage into the vic registers, so it's expected that the vic goes crazy.
To get it back you can copy the original state, and replace it once done.
If you break into the program you should be able to type goto30 to run the recovery code.
10 dimv(26):fori=0to25:v(i)=peek(36874+i):next
20 fori=1to200:poke36874+rnd(1)*25,rnd(1)*256:next
30 fori=0to25:poke36874+i,v(i):next
Hey thanks! Is there a way to do this without any effect on the screen?
- Stormcrow
- Website: http://trimboli.name
You just want random white noise?
When you're done listening, press STOP then RUN 40 to make the noise go away.
36877 is the white noise register (values 128–255), and 36878 is the volume (values 0–15).
10 POKE 36878,15
20 POKE 36877,RND(0)*128+128
30 GOTO 20
40 POKE 36878,0
50 POKE 36877,0
- Stormcrow
Or even more noise:
10 POKE 36878,15
20 POKE 36874+RND(0)*4,128+RND(0)*128
30 GOTO 20
40 FOR I=36874 TO 36878
50 POKE I,0
60 NEXT
That second one is exactly what I was looking for! Very cool! Thanks a lot!
