How do you clear the screen in machine language?
JRBasic
Occupation: Programmer
Post by JRBasic »
How do you clear the screen in machine language? I'm trying to make my first VIC-20 demo in CBM prg Studio.
20questions
Occupation: student
Re: How do you clear the screen in machine language?
Post by 20questions »
Bedroom coder=rock star
modern coder= pop star
i'd rather be a rock star than a pop start 8)
JRBasic
Post by JRBasic »
Thanks, cleared the screen as you said.
OmegaMax
Post by OmegaMax »
Might be a good idea to clear the screen memory with your own code instead of using the kernal,if your going to program the VIC in assembly,starting with small routines/code is a good idea.
Do_ClearScreenRam
  ldy #0
  lda #$20
ClearScreenRamLoop
  sta $1e00,y
  sta $1f00,y
  iny
  bne ClearScreenRamLoop
  rts
What type of demo are you doing?
OmegaMax
Post by OmegaMax »
Since your description says "Occupation: Programmer" then you understand pointers,so here's a small program that uses pointers.It clears the screen ram and then draws @ using a pointer.Copy code into CBM prg studio,feel free to play around with the code so you can understanding how it works.
*=$1001
 byte $0B,$10,$DC,$07
 byte $9E,$34,$31,$30,$39
 byte $00,$00,$00
 jmp Main
; VIC 20 Color Defines
Black = 0
White = 1
Red = 2
Cyan = 3
Purple = 4
Green = 5
Blue = 6
Yellow = 7
Orange = 8
LightOrange = 9
Pink = 10
LightCyan = 11
LightPurple = 12
LightGreen = 13
LightBlue = 14
LightYellow = 15
; Defines
ScreenRam = $1e00
GridCharacter = $00
BlankCharacter = $20
; Variables
Pointer = $00
Main
  jsr Do_ClearScreenRam
  jsr Do_DrawGridToScreenRam
LoopForever
  jmp LoopForever
Do_ClearScreenRam
  ldy #0
  lda #BlankCharacter
ClearScreenRamLoop
  sta ScreenRam+0,y
  sta ScreenRam+256,y
  iny
  rts
; Draw And Color Grid
  lda #>ScreenRam
  sta Pointer+1
  lda #<ScreenRam+44
  sta Pointer+0
  ldx #18                 ;ScreenRows
DrawNextRowLoop
  ldy #20                 ;ScreenColumns
DrawNextColumnLoop
  lda #GridCharacter
  sta (Pointer),y
  lda Pointer+1
  pha
  clc
  adc #$78
  sta Pointer+1
ColorNextColumn
  lda #Red
  sta (Pointer),y
  pla
  sta Pointer+1
  dey
  bne DrawNextColumnLoop
  lda Pointer+0
  clc
  adc #22
  sta Pointer+0
  lda Pointer+1
  adc #0
  sta Pointer+1
  dex
  bne DrawNextRowLoop
  rts
Forbidden64
Post by Forbidden64 »
OmegaMax wrote:Might be a good idea to clear the screen memory with your own code instead of using the kernal,if your going to program the VIC in assembly,starting with small routines/code is a good idea.
Even some of the most picky assembly folks on denial use the kernal routines as a convenient library of commands. It is good to know what the routine does, however. That said, once you do there is no reason not to use kernal routines unless you have/need a much faster/custom routine. I've heard even expert demo scene guys like Michael Steil say they use the floating point stuff built in because its fast and already there.
OmegaMax
Post by OmegaMax »
I write all my own code,but use whatever suits you best.
Forbidden64 wrote:Even some of the most picky assembly folks on denial use the kernal routines as a convenient library of commands. It is good to know what the routine does, however. That said, once you do there is no reason not to use kernal routines unless you have/need a much faster/custom routine. I've heard even expert demo scene guys like Michael Steil say they use the floating point stuff built in because its fast and already there.
The KERNAL routines are often useful, unfortunately the screen code has 22x23 hardcoded so if you are using a different size you have to end up writing your own.
