Mospeed: a basic v2 compiler
nippur72
de Lagash
Post by nippur72 »
There's a new cool basic V2 compiler for VIC 20 and C64:
https://github.com/EgonOlsen71/basicv2
Features:
- very fast, on average 10% faster than "Basic Boss"
- modern: cross compiles on the PC (generates a .prg)
- produces assembler source
- lots of fine-tuned optimizations
How to use it:
1) install Java or JRE (https://www.java.com/it/download/)
2) download Mospeed from here
3) extract the .ZIP file, (olnly the "dist" folder is needed)
4) copy the .bas program to compile in the "dist" folder
5) from the command prompt CD to the "dist" folder
6) run the compiler with
mospeed example.bas -target=example -platform=vic20
After compiling it, the file "example" can be loaded on VICE.
The "generatesrc" option generates the assembler if you want to have a look at it:
mospeed example.bas -target=example -generatesrc=true -platform=vic20
The project is active and issues can be submited on GitHub, the author reviews them quickly.
Mospeed by Egon Olsen
Re: Mospeed: a basic v2 compiler
interesting... might come in handy for some things. did anyone try it yet? is it target agnostic?
vicist
Post by vicist »
I gave it a go.
It only compiles C64 Basic programs as it uses the 64 BASIC and KERNAL routines. :(
nippur72
de Lagash
Post by nippur72 »
sorry, in the post above I forgot to include the VIC20 switch:
Kweepa
Occupation: Game maker
Post by Kweepa »
Sounds amazing!
vicist
Post by vicist »
I'll give it another go.
P.S. The example.bas is a C64 basic program and does not require the vic20 switch. It works fine.
Kweepa
Post by Kweepa »
I tried it with kweepout but the petcat output (to make the bas file) crashed the compiler.
I suspect lines like this are a problem:
.STRG "{home}"
(Probably should have converted this to a byte array instead?)
Also, the [generated assembler] code was enormous (not surprisingly) so I'd probably have to rewrite it to use 8k instead of unexpanded.
[To answer your questions below without derailing this thread too far, I let kweepa.com lapse when crunching at work a few years back and have only partially recovered it to kweepa.org. I just now uploaded kweepout there, and fixed up the original game thread and the announcement thread. Download]
nippur72
de Lagash
Post by nippur72 »
where I can get kweepout? the whole www.kweepa.com seems unreachable (chinese site appears).
Also, I cannot visualize your avatar Kweepa.
Post by R'zo »
I've been using austro compiler. It has limitations such as...
-you can't change the address it runs from
-because of the above this also limits your ability to
relocate character and screen locations.
-it doesn't allow for sys or usr commands or the use of
interupts.
Does this compiler share these or any other limitations?
nippur72
de Lagash
Post by nippur72 »
Yes, you can change the address, you can even change where variables must reside:
/progstart=xxxxx|$yyyy
/varstart=xxxxx|$yyyy
/varend=xxxxx|$yyyy
/runtimestart=xxxxx|$yyyy
It also allows the use of SYS, the registers A,X,Y are taken from $030C, $030D, $030E and are written back after the SYS routine ends.
I'm not sure about interrupts, do you mean to call a compiled basic code as interrupt handler?
Post by R'zo »
Can you run an irq parallel to to compiled basic?
nippur72
de Lagash
Post by nippur72 »
@Kweepa I managed to compile kweepout, there was a problem with "{cm-*}" that has been fixed. Also with "{left arrow}" that "petcat" renders as "_".
The result is a 13K file that doesn't run on unexpanded VIC, so I added the line:
0 poke648,30:poke36869,240:poke36866,150
to make it work with a 16K expansion. Now it's so fast that is barely playable :-)
Get it here: https://github.com/nippur72/8-bit-proje ... t-compiled
Needs a 16K expansion and starts with: SYS 8192
BTW, I noticed that the +3K version "kweepoutmc.prg" that you released is slightly different (screen size)... can we have the source for it too? I would like to compile it as well.
Kweepa
Post by Kweepa »
Oh, hah! Yes, it's totally unplayable! Needs a delay loop in there (that gets smaller as the game progresses).
KweepoutMC is mixed C/asm so your compiler wouldn't help...
Thanks!
