Here is a little game I made (originally for the PET 3032) with the Quetzalcoatl C Compiler for the Unexpanded VIC 20 - Gameplay is simple, but It was just to see if I could get a functional game made with the compiler.
Meteor Storm - Avoid the meteors with the A and D Keys
Meteor Storm (New Game)
- metstorm.zip
- (1.8 KiB) Downloaded 189 times
- AndyH
- Occupation: Developer
Re: Meteor Storm (New Game)
Brilliant. Very speedy. Got plans for something bigger now you've had success with the compiler?
For Sure - will be interesting as the runtime module is 1.5kb, levaing only 2kb for the actual game code - Meteor Storm is 529 bytes, so things will be a squash in the Unexpanded VIC - but that will just add to the challenge - the next phase will be to work out arrays for multi-object action.
- Kweepa
- Occupation: Game maker
Is the runtime monolithic, or can you avoid certain library functions to keep it small?
Monolithic i think - as it's only a beta when development ceased - there is a smaller, earlier runtime included in the download package - I will do some tests to see if there are any differences in final binary sizeKweepa wrote:Is the runtime monolithic, or can you avoid certain library functions to keep it small?
