make: *** No targets specified and no makefile found. Stop.
I was following the instructions for Mac OS X in the doc/building directory, they are the same as what you stated abovegroepaz wrote:what instructions?
you'll have to do
./autogen.sh
./configure
make
at the very least
option checking is yes
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... ./install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... no
checking for awk... awk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking build system type... x86_64-apple-darwin15.6.0
checking host system type... x86_64-apple-darwin15.6.0
using TextField widget.
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking whether make supports the include directive... yes (GNU style)
checking dependency style of gcc... gcc3
checking for ld used by GCC... /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld
checking if the linker (/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ld) is GNU ld... no
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking whether termios.h defines TIOCGWINSZ... yes
checking if the compiler supports -march=native... yes
checking for ar... ar
checking for ranlib... ranlib
checking for strip... strip
checking for svn... svn
checking for tar... tar
checking for svnversion... svnversion
checking whether ln -s works... yes
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for byacc... no
checking for yacc... yacc
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -ll
checking whether yytext is a pointer... yes
checking if ar truncates object names... /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libvicetest.a(some_long_object_name.o) has no symbols
no
checking if ar complains about the 'u' option... yes
using ar wrapper instead of ar directly
checking for makeinfo... ${SHELL} /Users/Ben/desktop/vice-3.2/missing makeinfo
checking for texi2dvi... texi2dvi
checking for pdftex... no
checking for dos2unix... no
checking for xa... no
checking for xa65... no
configure: error: xa is missing
Making all in src
generating translate.h...
generating infocontrib.h...
config.status: creating src/config.h
config.status: src/config.h is unchanged
Making all in resid
Making all in resid-dtv
Making all in samplerdrv
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libsamplerdrv.a(portaudio_drv.o) has no symbols
Making all in joyport
Making all in sounddrv
Making all in mididrv
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libmididrv.a(midi-osx-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libmididrv.a(midi-unix-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libmididrv.a(midi-win32-drv.o) has no symbols
warning: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: warning for library: libmididrv.a the table of contents is empty (no object file members in the library define global symbols)
Making all in socketdrv
Making all in hwsiddrv
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(catweaselmkiii-amiga-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(catweaselmkiii-beos-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(catweaselmkiii-dos-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(catweaselmkiii-unix-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(catweaselmkiii-win32-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(cw-amiga-clockport.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(cw-amiga-device.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(cw-amiga-openpci.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(cw-amiga-os4.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(cw-amiga-zorro.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(cw-unix-device.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(cw-unix-pci.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(cw-win32-dll.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(cw-win32-pci.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hardsid-amiga-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hardsid-beos-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hardsid-dos-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hardsid-unix-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hardsid-win32-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-amiga-gg2isa.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-amiga-openpci.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-amiga-os4.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-beos-isa.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-beos-pci.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-dos-isa.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-dos-pci.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-unix-isa.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-unix-linux.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-unix-pci.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-win32-dll.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-win32-isa.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(hs-win32-pci.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(parsid-beos-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(parsid-dos-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(parsid-unix-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(parsid-win32-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(ps-ieee1284.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(ps-unix-file.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(ps-unix-io.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(ps-win32-dll.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(ps-win32-io.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(ssi2001-amiga-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(ssi2001-beos-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(ssi2001-dos-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(ssi2001-unix-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libhwsiddrv.a(ssi2001-win32-drv.o) has no symbols
warning: /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: warning for library: libhwsiddrv.a the table of contents is empty (no object file members in the library define global symbols)
Making all in iodrv
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libiodrv.a(io-beos-access.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libiodrv.a(pci-beos-drv.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libiodrv.a(pci-dos-drv.o) has no symbols
Making all in drive
Making all in iec
Making all in c64exp
Making all in plus4exp
Making all in iec128dcr
Making all in iecieee
Making all in ieee
Making all in tcbm
Making all in vdrive
Making all in fsdevice
Making all in diskimage
Making all in iecbus
Making all in serial
Making all in parallel
Making all in tape
Making all in imagecontents
Making all in fileio
Making all in video
Making all in raster
Making all in vicii
Making all in viciisc
Making all in viciivsid
Making all in vdc
Making all in crtc
Making all in gfxoutputdrv
Making all in printerdrv
Making all in rs232drv
Making all in sid
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libsid.a(catweaselmkiii.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libsid.a(parsid.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libsid.a(ssi2001.o) has no symbols
Making all in monitor
Making all in core
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libcore.a(cs8900.o) has no symbols
Making all in rtc
Making all in userport
Making all in tapeport
Making all in diag
Making all in c64
Making all in cart
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libc64cart.a(c64-midi.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libc64cart.a(clockport-rrnet.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libc64cart.a(rrnetmk3.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libc64cart.a(shortbus_etfe.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libc64commoncart.a(cs8900io.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libc64commoncart.a(ethernetcart.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libvsid.a(c64embedded.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libc64.a(c64embedded.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libc64sc.a(c64embedded.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libc64scpu64.a(c64embedded.o) has no symbols
Making all in scpu64
Making all in c64dtv
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libc64dtv.a(c64dtvembedded.o) has no symbols
Making all in c128
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libc128.a(c128embedded.o) has no symbols
Making all in vic20
Making all in cart
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libvic20cart.a(vic20-midi.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libvic20.a(vic20embedded.o) has no symbols
Making all in pet
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libpet.a(petembedded.o) has no symbols
Making all in plus4
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libplus4.a(plus4embedded.o) has no symbols
Making all in cbm2
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libcbm2.a(cbm2embedded.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libcbm5x0.a(cbm5x0embedded.o) has no symbols
Making all in arch
Making all in sdl
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libarch.a(menu_debug.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libarch.a(menu_ethernet.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libarch.a(menu_ethernetcart.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libarch.a(menu_ffmpeg.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libarch.a(menu_midi.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libarch.a(rawnetarch.o) has no symbols
Making all in lib
Making all in p64
In file included from info.c:34:
./infocontrib.h:293:8: warning: illegal character encoding in string literal
[-Winvalid-source-encoding]
" Andr<E9> Fachat <fachat@physik.tu-chemnitz.de>\n"
./infocontrib.h:343:12: warning: illegal character encoding in string literal
" Paul Dub<E9> \n"
./infocontrib.h:444:8: warning: illegal character encoding in string literal
" Istv<E1>n F<E1>bi<E1>n\n"
./infocontrib.h:532:11: warning: illegal character encoding in string literal
" Frank K<F6>nig <frank_koenig@t-online.de>\n"
./infocontrib.h:571:11: warning: illegal character encoding in string literal
" Marko M<E4>kel<E4> <msmakela@gmail.com>\n"
./infocontrib.h:622:10: warning: illegal character encoding in string literal
" Lasse <D6><F6>rni <loorni@mail.student.oulu.fi>\n"
./infocontrib.h:655:14: warning: illegal character encoding in string literal
" Pablo Rold<E1>n <pdroldan@yahoo.com>\n"
./infocontrib.h:799:19: warning: illegal character encoding in string literal
" Peternel, Per H<E5>kan Sundell and David Horrocks for writing\n"
./infocontrib.h:841:25: warning: illegal character encoding in string literal
{ "1996-2001", "Andr<E9> Fachat", "Andr<E9> Fachat <fachat@physik.tu-chemnitz.de>" },
./infocontrib.h:841:41: warning: illegal character encoding in string literal
./infocontrib.h:862:29: warning: illegal character encoding in string literal
{ "2004-2017", "Paul Dub<E9>", "French", "Paul Dub<E9> " },
./infocontrib.h:862:52: warning: illegal character encoding in string literal
12 warnings generated.
ld: warning: ignoring file /usr/local/lib/libz.dylib, file was built for i386 which is not the architecture being linked (x86_64): /usr/local/lib/libz.dylib
Undefined symbols for architecture x86_64:
"_gzclose", referenced from:
_zfile_fopen in zfile.o
_zfile_fclose in zfile.o
"_gzopen", referenced from:
"_gzread", referenced from:
"_gzwrite", referenced from:
ld: symbol(s) not found for architecture x86_64
clang: fatal error: linker command failed with exit code 1 (use -v to see invocation)
make[3]: *** [vsid] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all] Error 2
make: *** [all-recursive] Error 1
groepaz wrote:those errors come from missing "zlib", try installing that via brew or macports or whatever you used to install gtk3
the macOS build process is quite new, and errors are to be expected - its good someone who doesnt have all the development stuff already installed tries it, so we can see what is missing in the instructions
checking for GTK... configure: error: Package requirements (gtk+-3.0 >= 3.16) were not met:
Package 'pango', required by 'gdk-3.0', not found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables GTK_CFLAGS
and GTK_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
Ok, thank you or your assistance! I will report a bug.groepaz wrote:urks... at this point it becomes really macOS specific, no idea what to do perhaps report a bug on sourceforge: https://sourceforge.net/p/vice-emu/bugs/
groepaz wrote:unfortunately, yes (that was necessary because of spam).
alternatively, you could join IRC on freenode #vice-dev in late evenings (EST) and talk to some macOS guy directly
