WANTED: VIC-20 Shift-Lock Mechanism
Vic 20 Item Exchange
TheMightyMadman
Website: https://retrorepairsandrefurbs.com/
Occupation: Electronic Engineer
Post by TheMightyMadman »
Hi all,
I'm desperately looking for a Commodore 64 shift-lock mechanism with a round barrel, which I believe is the same as the one on most VIC-20s (they used VIC-20 style keyboards for both early and late 64s). It's all-black and should have two long wires coming out the back of it. It will come from a keyboard that doesn't have springs underneath the keys, and has rubber plungers on the PCB instead. I've been looking for one for ages but I haven't had any luck so far, so if anyone happens to have a spare they'd be willing to sell I'd appreciate it!
Many thanks,
Adam
PET 3032 • 4040 • C64 • C64G • C64C • SX-64 • C128 • C128D • C16 • C116 • Plus/4 • VIC-20 • VIC-1541 • 1541 • 1541C • 1541-II • 1551 • 1570 • 1571 • 1581 • 1701 • 1084S-D2
Looking to buy: https://retrorepairsandrefurbs.com/looking-to-buy/
Re: WANTED: VIC-20 Shift-Lock Mechanism
TheMightyMadman wrote:... It will come from a keyboard that doesn't have springs underneath the keys, and has rubber plungers on the PCB instead.
This detail or the photo you provided helps very little in knowing what type of keyboard you have.
There are generally 3 types of keyboard equipping VIC-20s. They are easiest to identify with the typeface used. The difference is most obvious on the 'SHIFT' keys.
TheMightyMadman
srowe wrote:Have you tried this guy?
https://www.ebay.co.uk/itm/COMMODORE-VI ... SwC19bFtIv
Very well spotted, thank you! I've messaged them, hopefully it's still available. I appreciate it :-)
TheMightyMadman
The picture may not be helpful in terms of the keyboard, but it is for the mechanism itself. I guess the description is more suited to 64 keybaords, but it still applies. I figured that most people who would know the kind of VIC-20 keyboards would know the kind of VIC-20 shift-lock mechanisms too. Also, having a spare lying around you're not going to necessarily know what kind of keyboard it came from. Out of interest, are the typefaces guaranteed to be standard between the types, if that makes sense?
TheMightyMadman wrote:The picture may not be helpful in terms of the keyboard, but it is for the mechanism itself. I guess the description is more suited to 64 keybaords, but it still applies. I figured that most people who would know the kind of VIC-20 keyboards would know the kind of VIC-20 shift-lock mechanisms too. Also, having a spare lying around you're not going to necessarily know what kind of keyboard it came from. Out of interest, are the typefaces guaranteed to be standard between the types, if that makes sense?
This comment does not help me identify which type of keyboard you have.
3 types of keyboards for the VIC-20
I'm not going to disassemble my keyboards to know which one has your specific shift lock switch.
What you should do is post a photo of one of your SHIFT keys.
TheMightyMadman
This arrived the other day and is exactly what I needed, thank you very much! I appreciate it :D
TheMightyMadman
eslapion wrote:What you should do is post a photo of one of your SHIFT keys.
For the record, here is a picture of the keyboard in question, which matches the top keyboard style in your picture.
