Custom Char Set and Memory
plbyrd
Website: http://thesharp.ninja
Occupation: Software Engineer
Postby plbyrd » Mon Aug 21, 2017 9:24 am
Is it possible to tuck a custom char set under the char rom ala C64? Or is that a special feature of the 6510?
Re: Custom Char Set and Memory
Postby tokra » Mon Aug 21, 2017 10:06 am
There is no RAM under ROM on the VIC-20. That is a special feature of the 6510. On the VIC-20 you can only put custom chars (and the video-RAM) in the RAM-area of the unexpanded VIC ($0000-$03ff and $1000-$1fff). The first 1K-area at $0000-$03ff does not make a lot of sense for custom chars in most cases but is possible anyway.
plbyrd
Postby plbyrd » Mon Aug 21, 2017 10:16 am
OK, thanks. I'm going to use a modified version of the C128 character set. I need to use some special glyphs for the display and the C128 font looks awesome on the VIC20.
Postby Mike » Tue Aug 22, 2017 1:09 am
To be exact, what the VIC-II chip 'sees' in the C64 has nothing to do with the 6510 (port) at all.
What is addressed by VIC-II is selected by the PAL IC, independent on the 6510's port settings; VIC-II only sees the C64 RAM with the exception of two mirror copies of the character ROM at $1000..$1FFF and $9000..$9FFF (unless there's Ultimax-Mode active). The 6510 has its own copy of the character ROM selected at $D000..$DFFF with /CHAREN=0 and at least one of /LORAM or /HIRAM =1.
Return to “Programming”
Who is online
