TAP files an the PET
ViperSan
Post by ViperSan »
So ...I finally repaired my PET4032 ...and my 8050 dual floppy ...
Now I want to get space invaders on it ..
I have downloaded a TAP file of space invaders for the PET ...dumped this to audio cassette with Audiotap ....
popped the cassette in a datasette attached to the PET ...and set it to load ..
the Load completes ...but the ML programme is not in the correct location in memory ...thus I cannot run it..
I'm assuming audiotap is generating an unsuitable header...probably for C64 or VIC
Is there a version of audiotap specifically for the PET ...or an easy fix to relocate the space invaders program in memory..
any help appreciated..
rgds
VS
mrr19121970
Re: TAP files an the PET
Post by mrr19121970 »
Why not play around with it in VICE 1st?
Can you post a link to the TAP file you are trying
mrr19121970
There is a version here http://www.classic-computers.org.nz/blo ... wnload.htm
that loads, but crashes after the 1st screen.
Using FinalTap you can extract the PRG. You need to correct the header in a HEX editor from 01 08 to 01 04 to get it to run (still crashes in VICE)
Website: http://hugbox.org/
ViperSan wrote:I'm assuming audiotap is generating an unsuitable header...probably for C64 or VIC
That's fortunately not right. Audiotap converts TAPs without any change of content.
Could a 'LOAD "*",1,1' do the trick and load it to the right address?
ViperSan
Post by ViperSan »
mrr19121970 wrote:There is a version here http://www.classic-computers.org.nz/blo ... wnload.htm
When you say 'crashes after the first screen' ...I assume you mean after displaying the audio mod via parallel port screen ..
That is the same one I downloaded ...and it does just that ..
loads ...
displays the parallel port mod page for sound ...
then pressing any key results in a blank screen ..and crash..(presumably)
it just hangs..
rgds
VS
mrr19121970
Download the PRG from zimmers. This works fine (doesn't crash after audio mod screen).
http://www.zimmers.net/anonftp/pub/cbm/ ... vaders.prg
ViperSan
Post by ViperSan »
mrr19121970 wrote:Download the PRG from zimmers. This works fine (doesn't crash after audio mod screen).
..that is a PRG file which I will presumably need to convert to TAP ...
Could you outline how to do this please ?
rgds
VS
mrr19121970
norm8332
Post by norm8332 »
Hmmm.. I used my 4040 drive since it could read 1541 disks. Then I made a PetDisk. It's like an SDIEC but for a PET. They can be built with plans on the internet or purchased. http://www.bitfixer.com/bf/petdisk and http://blog.tynemouthsoftware.co.uk/201 ... drive.html
This works on a PET also for .TAP files: https://hackaday.io/project/1985-tapuin ... e-emulator
-Autobiography of Mark Twain
