How to determine if a file exists or not?
Bobbi
Occupation: Programmer
Postby Bobbi » Thu Apr 06, 2017 5:34 pm
I am wondering what is the correct way to determine if a file on disk exists or not under the VIC-20 kernal / Commodore DOS.
If I do the following in BASIC:
10 OPEN2,8,2,"DOESNTEXIST,S,R"
20 GET#2,A$
30 PRINTASC(A$)
40 CLOSE2
It prints 199. Is that some magic value meaning end-of-file? The 1541 User's Manual does not provide much assistance here. Is there a better programmer's reference for disk stuff?
Bobbi
Re: How to determine if a file exists or not?
Postby Bobbi » Thu Apr 06, 2017 5:36 pm
I think I answered my own question. I should look at the value of ST. The '64' bit is end-of-file.
20 GET#2,A$
30 IF (ST AND 64) <> 0 THEN GOSUB 1000
40 CLOSE 2
50 END
1000 PRINT "DOESN'T EXIST"
1010 RETURN
Bobbi
Postby Bobbi » Thu Apr 06, 2017 6:11 pm
However this doesn't distinguish between zero-length file and a file that truly does not exist. How to do that?
Postby Mike » Thu Apr 06, 2017 11:09 pm
CBM DOS can't have zero-length files. *) ;)
However, you can (try to) rename a file into itself and check the error channel, like thus:
10 DN=PEEK(186):INPUT"FILE";N$
15 OPEN15,DN,15,"R0:"+N$+"="+N$:DS$=""
20 GET#15,A$:DS$=DS$+A$:IFST=0THEN20
25 CLOSE15:PRINTDS$
Unless there are other issues (like write protect on, or drive not ready, etc.), you either get 62,FILE NOT FOUND,00,00 or 63,FILE EXISTS,00,00 in DS$ ... which exactly match the information you want to know. :)
And this method also has the charm it works independent of CBM DOS file type.
*) actually your example would instead fail with files of one byte length, as EOF in ST already is signalled with the last byte sent!
Edit: actually, CBM DOS doesn't correctly handle one-byte-length files, either - in both cases (zero-length, one byte) a read back results in a file having four bytes length. This happens on the 1541 and 1581 (and presumably, also the 1571).
Bobbi
Postby Bobbi » Fri Apr 07, 2017 7:37 am
Thanks Mike. Glad I asked - not sure I would have come up with that solution on my own!!
Return to “Programming”
Who is online
Users browsing this forum: No registered users and 0 guests
