Latest firmware for SD2IEC?
Out of interest what is the latest recommended SD2IEC firmware for the FE3? Mine reports V0.10.3 which is five years old. Do the latest builds on http://www.sd2iec.de work with the FE3?
Re: Latest firmware for SD2IEC?
I see no reason why they should not work. Sadly, some hardware guys still believe the current binaries to be "alpha" oder "beta"-releases, but the author has stated himself on Forum64.de that the newer releases are no more alpha or beta than the 0.10.3-release. So, you should be able to always use the latest release.
tonyrocks
Website: http://www.tonyrocks.com
Occupation: IBM Watson Engr
Post by tonyrocks »
I prefer not to touch mine. Everything is working just fine :) unless there is some new feature that would blow my mind...
SkydivinGirl
Post by SkydivinGirl »
I've been shipping the Rev 11 with sd2iec-1.0.0atentdead0-7-gd321454-larsp-m1284p, which is from 9/9/2016. The latest version should work without issue on the Rev 9, 10, or 11 since they are all functionally the same. :)
Heather
