Hello everyone, very new not only here, but to the Vic-20 all around! Just received my very first Vic-20 from a friend who found one in his friends attic.
I have a question about connecting the system to a display. The cable that I have to connect it to a TV/monitor is the cable that bypasses a modulator. (5 pin on one side, dual RCA style on the other end.) When I plug the cable into my modern HDTV with the composite cable, I have no problem getting a display. However when I went to plug it into a CRT television (from 1987 no less), I was unable to get a display to show. The CRT television requires an RF modulator to use coaxial, and when I turn the Vic on, the modulator detects the signal, but does not display the system. I tried hooking up other devices to the CRT TV that way, and it was working fine. Is there something I am doing wrong? I would have thought it would have been harder to get it to work on an HDTV but it ended up being the other way around, and I am unable to get it to work on a TV that was made in the same era!
Also, I have a Commodore Amiga 1080 monitor that I use for my Amiga 1000. I was wondering if that monitor was compatible with the Vic-20 since it has similar RCA style connection inputs as an option on the rear aside from the RGB video port. When I tried to use the monitor, with every connection and switch set to every position (both the front and rear selection switches), I still could not get a signal.
Does anyone have any suggestions to get me started? I didn't want to hook it up to the 50" HDTV, I'd rather use a smaller CRT so that it can be a part of my other retro computers on my desk... But for some reason I'm stumped and I wanted to know if I was doing something wrong, since I've never owned a Vic-20 before.
Thanks in advance,
-Kris
Vic-20 TV/Monitor Connection Questions
Re: Vic-20 TV/Monitor Connection Questions
Hi, Kris.
The 1080 should work with the VIC-20 if both share the same TV system (NTSC or PAL): white connects to (mono) audio, yellow to video (composite). Red (chroma) isn't used, unless you happen to own a VIC-20 modded for S-Video.
Since you got your VIC-20 working on your new TV, this is a strong hint, that the RF modulator is defective. Unfortunately, this is something that can't be fixed without the means of an electronic workshop at hand.xanfan wrote:The CRT television requires an RF modulator to use coaxial, and when I turn the Vic on, the modulator detects the signal, but does not display the system.
- mrr19121970
- Vic 20 Nerd
According to this:
https://ia801709.us.archive.org/10/item ... ore_US.pdf
The 1080 has only RGB, You need CVBS to use your VIC20
Did you go to page 2 of the PDF to check the inputs ?mrr19121970 wrote:According to this:
It says:
Having had a monitor like that from 1989 to 2015, I can tell you it works perfectly well with both the C64 and VIC-20 and it was the only CRT monitor I had which would display PAL (in B/W since colors are encoded at a different frequency).
- NTSC Composite
NTSC with separate chroma and luminance
This is the only image I could find on the web that matches what I remember about the backside of the 1080:
The composite video connector is the center RCA jack.
Then you have to set the switch in the front panel to the correct position - there are 3 possible positions:
If you set it to composite, you'll get the correct image. Set it to separate and you'll get a B/W image but you'll have something.
If you have no display then the problem is either with the VIC-20 or cabling.
You can "test" your monitor with a VCR or DVD with standard "Video Out" to make sure it has no technical issues.
- RGB - a switch in the back selects RGB Analog or digital RGBi
- Composite
- Separate
First of all, thank you to everyone that has given me some guidance in trying to get my Vic-20 up and running! I tested the Vic-20 on another CRT television that has component jacks, and it worked perfectly. I also tested out a portable DVD player on both the other TV that I had (the one that needed the RF modulator), as well as on the Amiga monitor. Neither worked, so I assume that the RF modulator (which I remembered was giving me issues a long time ago) must not be working right, and that the composite ports in the rear of the Amiga monitor I suppose are defective? (I've never used them before so they were never tested.) I assume there is no easy way to repair those ports that doesn't involve getting invasive...?
At least I know that the computer itself is still working, which is a good sign. I can always get another TV with proper inputs so I can bypass the modulator all together, or I can buy another modulator! (At least I know where I am standing at this point.)
Thanks again to everyone for their suggestions and recommendations!
-Kris
-Kris
