6502 Assembler Help
tonyrocks
Website: http://www.tonyrocks.com
Occupation: IBM Watson Engr
6502 Assembler Help
Post by tonyrocks »
Hey guys,
I'm in the process of "re-learning" assembler and found some generic 6502 assembler code. I'm trying to find the equivilant commands for commodore 64 or vic-20. I'm a little confused on what sta $200,y does and how to convert to vic-20 asm.
Here is an example of soemthing I grab from online:
start:
 inx ;increment x register
 txa ;transfer X to a
 sta $200, y
 sta $300, y
 sta $400, y
 sta $500, y
 iny
 tya
 cmp 16
 bne do
 iny
 jmp start
do:
 iny
 iny
 iny
 iny
jmp start
Thanks!
Re: 6502 Assembler Help
tonyrocks wrote:I'm a little confused on what sta $200,y does and how to convert to vic-20 asm.
STA $0200,Y writes the value of the accumulator A into the address defined by adding the Y index register to $0200. In BASIC, the command POKE 512+Y,A (with A,Y = 0..255) would be the direct equivalent. Whether thrashing bytes in the range $0200..$02FF on the VIC-20 is a good idea, is altogether another matter - but that's what the instruction also does on the VIC-20's 6502, regardless.
Your example endlessly writes to $0200..$05FF ever increasing values (derived from the X register by TXA) to every second byte, leaving a gap of 4 bytes should the low byte of the addresses become equal to either 16 (with an implied # in the CMP instruction), or the value in address 16 (if the instruction CMP 16 is meant as is). As complicated as this sounds, this routine IMO serves no conceivable use. You might be better off looking for routines, that have been written with an actual (machine independent) use for the 65xx series in mind. http://6502.org might serve as a useful start point.
If you find compelling examples of 6502 routines written for the VIC-20, we can of course also discuss them here in Denial. :mrgreen:
Kakemoms
Post by Kakemoms »
Since both machines use a 6502-based core, all the assembler instructions are the same. The only difference is what different memory locations do, and for that you can look at the Vic-20 & C64 memory map here:
http://www.commodore.ca/manuals/pdfs/co ... ry_map.pdf
If you want to do something graphics related, C64 code can't immediately be translated to the Vic-20 since the two machines have quite different graphics processors (the C64 having double the resolution for horizontal axis compared to the Vic-20).
tonyrocks
Post by tonyrocks »
thank you! that chart is very useful.
Bobbi
Occupation: Programmer
Post by Bobbi »
I find this one helpful too:
http://www.zimmers.net/cbmpics/cbm/vic/memorymap.txt
(same info, different format.)
