Do "easier" DIP switches exist?
I have an easily removed "eight number" DIP switch on a flash cart. It is a pain to routinely consult a chart when selecting a number. Is there an easier solution to go through the 256 options?
I imagined a simple LCD or LED digital number device that, by pressing buttons, could advance the number. Something you might find on a pedometer or cheap, tiny alarm clock. But with the same pins to swap/replace the DIP switch component. Anything like that exist?
xavier
Re: Do "easier" DIP switches exist?
Post by xavier »
... Or two hexadecimal encoders...
4bits+4bits="F"+"F"=&FF=256.
(Easy to set)
http://www.conrad.fr/ce/fr/product/7054 ... view1&rb=1
I have the "piano" type switches. None of the rotary ones seem to use the same pin layout.
mrr19121970
Post by mrr19121970 »
How about an ardiuno and 2x16 LCD display?
Jeff-20 wrote:I have an easily removed "eight number" DIP switch on a flash cart. It is a pain to routinely consult a chart when selecting a number. Is there an easier solution to go through the 256 options?
I think what you're looking for is an 8-bit binary counter that has the same footprint as an 8 way DIP switch. You could probably build something that fitted but I don't think there's anything off-the-shelf.
