[RESOLVED] VC20 (no serial number)
mrr19121970
Re: VC20 (no serial number)
Post by mrr19121970 »
Socketed & replaced UD8 & UE8. No change black screen only. No blind disk commands, no 'reset' signal received by floppy
mrr19121970
Maybe onto something now. Desoldered UD2-UD6 and UE1-UE6. Tested them in the colour ram of this machine and found 1 out of 11 that was bad (the rest are all good). Will socket tomorrow and try a spare RAM.
Also socketed UB4, UB6, UC4, UC5, UC6, UD9 & UF8 today. I might as well finnish off UB9, UB10, UC1, UC3, UD1 and then I have a fully socketed board if the RAM turns out to be the cause here.
Also managed to break my 1084, had a dodgy on-off switch that didn't always go off. Now it won't go on anymore.
mrr19121970
Well screen is still black, tested all memories again. Still all ok. Last one to try is UD9 (I ordered some 133 logics yesterday). After this I think I can't save this one from the landfill. Will have to become a 'spare parts' donor with so many low dated & working components.
mrr19121970
Anyone recommend anywhere else to be testing with oscilloscope?
mrr19121970 wrote:No blind disk commands, no 'reset' signal received by floppy [...] Also socketed UB4, UB6, UC4, UC5, UC6, UD9 & UF8 today. [...] Anyone recommend anywhere else to be testing with oscilloscope?
If the drive still doesn't get a reset signal, the 6502 in the VIC-20 most probably won't either.
Do you see a low-level pulse at pin 40 of the 6502 directly after power-on? Probe the signals around UB6 (555) and UB4 (7406) with extreme scrutiny. Compare the charging of C10 and C13 with a working unit. If in doubt, replace these two capacitors, R9 (220K), R14 (1.5M) and also R3 (1K).
mrr19121970
Mike wrote: If the drive still doesn't get a reset signal, the 6502 in the VIC-20 most probably won't either.
I was mistaken here. Was using a SD2IEC. Tried with a real drive it got the reset
Mike wrote:Do you see a low-level pulse at pin 40 of the 6502 directly after power-on? Probe the signals around UB6 (555) and UB4 (7406) with extreme scrutiny. Compare the charging of C10 and C13 with a working unit. If in doubt, replace these two capacitors, R9 (220K), R14 (1.5M) and also R3 (1K).
I will check this.
I now tested the original locic chips and all are working
UB4 : 7406
UD8, UE8 & UEF9 : 74LS245
UE4, UC5 & UC6 : 74LS138
UD9 : 74LS133
UB6 : LM555
mrr19121970
I compared the 'pattern' on a working machine with this one. PIN40 6502 looks the same, small ripple for a few seconds then flat 5v
mrr19121970
I believe the capacitors and resistors are also fine.
Can you try to probe the address bus activity of the CPU?
Normally, while the VIC-20 is idle in the "READY." prompt, the PC is in a tight loop at $E5E8 .. $E5F0:
.E5E8  A5 C6     LDA $C6
.E5EA  85 CC     STA $CC
.E5EC  8D 92 02  STA $0292
.E5EF  F0 F7     BEQ $E5E8
This pattern repeats every 13 Cycles, and should produce a discernible waveform on each bit of the address bus:
$E5E8 = %1110010111101000
$E5E9 = %1110010111101001
$00C6 = %0000000011000110
$E5EA = %1110010111101010
$E5EB = %1110010111101011
$00CC = %0000000011001100
$E5EC = %1110010111101100
$E5ED = %1110010111101101
$E5EE = %1110010111101110
$0292 = %0000001010010010
$E5EF = %1110010111101111
$E5F0 = %1110010111110000
$E5F1 = %1110010111110001 (taken branch, internal cycle)
Now just read off the columns to probe the signal for a certain address bit.
During the keyboard interrupt, the PC will of course be located at another place. But if the 6502 is completely somewhere else, that should also give a good hint where the problem might be located (and in that case, please tell the suspected PC range).
mrr19121970
I Don't know how to do this
You do it the same way as you did with the clock signals: connect the ground clamp of the probe to a ground plane somewhere near the 6502, and then hold the probe tip onto each of the address bus pins of the CPU at a time.
A13, A14 and A15 for example (at pins 23, 24 and 25, respectively) then should all show the following waveform for most of the time:
110111011111011011101111101101110111110 ... (starting the list at $E5EA, and then repeating):
or
__ ___ _____ __ ___ _____ __ ___ _____
  _   _     _  _   _     _  _   _     _
mrr19121970
This is what I see
mrr19121970
The pattern is different to a working 6502
Can you confirm the pattern in my posting above on a working VIC-20?
Those three flat-lines could indicate, that the CPU spins somewhere in the RAM address range ($0000..$1FFF) - do you see *any* activity in the lowest address bit (bit 0 = pin 9)?
Please also check the logic level at the /IRQ and /NMI pins of the CPU (IRQ = pin 4, NMI = pin 6) - a stuck-on-0 on the IRQ, or a flakey signal on the NMI (NMI is edge-sensitive) could put the CPU into an eternal interrupt loop.
mrr19121970
I do this tomorrow after work. Just reassembled both VIC20s and packed away.
