I bought the 'Penultimate Cartrige' v2.2 from Tynemouth. Here I have 3 diagnosis carts on 2 for PAL (not sure what the differences are) and 1 for NTSC.
Before I was trying to run the diagnosis for an NTSC machine, and was annoyed to find a BAD on ROMCHECK. Long story short, now on 4 out of my 5 NTSCs and the can't all be bad. This draws me to the conclusion is the ROMCHECK is bad on this cart image.
Does anyone recommend a program that I can run to check the ROMs? and also recommend a working diagnosis cart image for NTSC.
NTSC VIC20 Diagnosis Cartridge
- mrr19121970
- Vic 20 Nerd
- mrr19121970
- Vic 20 Nerd
Re: NTSC VIC20 Diagnosis Cartridge
Ok. There are too many dip switches. I needed to.activate 12 567 9 for the cart. I forgot 2 which meant that there was no extra memory activated. I guess the cart needs this, but doesn't mention that it is not there. Just gives false positives. All working now.
My question is still valid though. AnyOne recommend any further rom check utilities??
You could use a VERIFY with three *.prg files that contain CHAR, BASIC and KERNAL ROM.mrr19121970 wrote:Does anyone recommend a program that I can run to check the ROMs?
Here's a small programm I wrote for a soak-test checksum of the BASIC ROM.
- mrr19121970
- Vic 20 Nerd
Great. Thanks. Just what I was looking for.
