Thanks for the confirmation. The way I work on these disassemblies is I note oddities when I notice them and then come back when I understand the code better.
I'm struggling to recall my reasons for this. I think I did it because my NMI handler does not check for the A0CBM signature. If something intercepts the NMI vector it's highly likely to break my code anyway.On a related note, I have a suggestion for your latest RS 232 fix (the one in BLK5). You set the warmstart entry to point to $0000, ...
... as some software could however divert the NMI vector or re-initialise it to the KERNAL default, you should rather point that entry to $FEC7 instead.Code: Select all
* = $A000 .WORD RSCOLD .WORD 0 ; unused .BYT "A0",'C'+$80,'B'+$80,'M'+$80
This continues the original NMI code after $FEC4 JMP ($A002), so when the KERNAL or some other program (like MINIMON) checks for the A0CBM signature, the KERNAL vectors are reset but at least it does not crash.
Interestingly, I happen to be working on more RS-232 code at the moment. Only this is interfacing to a real UART (16550A).
Thanks
Simon
