UltiMem
telengard
Re: UltiMem
Post by telengard »
brain wrote:What file are you using (link?) I will try it here.
Jim
Hi Jim,
I got the files from here:
http://www.go4retro.com/downloads/UltiMem/
I am using flash4file.prg and ultimem8m.img (renamed to ultimem.bin as suggested).
brain
Re: UltiMem
Post by brain »
That's an image file for VICE. Use the ultimem.bin file that is 4.8MB
Jim
telengard
Re: UltiMem
Post by telengard »
brain wrote:That's an image file for VICE. Use the ultimem.bin file that is 4.8MB
Jim
Thanks Jim, I'm now having power issues w/ my VIC but once that is resolved I'm sure things will work OK.
thanks for your help!
Barney
Re: UltiMem
Post by Barney »
So is the Ultimem completed and can it be purchased? I am definitely interested.
brain
Re: UltiMem
Post by brain »
telengard
Re: UltiMem
Post by telengard »
Forgot to post back here that all is working. Using the image suggested work and I also resolved my power issue (loose fuse holder).
thanks everyone!
akator
Re: UltiMem
Post by akator »
I finally purchased an UltiMem this month. After flashing the "official image," I'm very impressed with how great this is. I wish I had purchased one years ago and definitely recommend it.
