V-FORTH - Forth-83 for the VIC
Re: V-FORTH - Forth-83 for the VIC
funkheld wrote: Wed Sep 11, 2019 2:18 pm hello, thanks for the help.
Will the compiler bug be fixed?
Sure, I've tracked it down to 0>
-32767 0> . 0 ok
-32768 0> . -1 ok
The problem is 0> is defined as
: 0> negate 0< ;
and -32768 negate returns -32768.
This bug came in when I converted to Forth-83, I copied the implementation from someone else's code.
I need to think how to fix this given the very limited space available, the core code must be less than 8K to fit in the ROM image.
can you put down an asm program at $a000 and call "CALL $ a000"
Thank you.
Greeting
There are a couple of ways.
system.fs defines sys that allows you to call machine code just like from BASIC, you pass register values in using the variable sareg, sxreg and syreg and on return those variables contain the results.
assembler.fs allows you to define words that contain machine code
include assembler
hex
code test
    2a # lda,  ffd2 jsr,  next jmp,
end-code
The code called must not over-write the parts of zero page that V-FORTH uses, and if you are using the assembler you must preserve .X as this is the data stack pointer.
funkheld
Post by funkheld »
Hi good afternoon.
when I come to the assembler loading "MSG # 4".
what is that?
Thank you.
greeting
funkheld wrote: Thu Sep 12, 2019 7:22 am when I come to the assembler loading "MSG # 4".
what is that?
MSG #4 is a word redefinition warning, the check isn't clever enough to handle the fact it is in a separate vocabulary.
Errors are documented here
https://eden.mose.org.uk/gitweb/?p=vfor ... xt;hb=HEAD
funkheld
Post by funkheld »
hello thanks for the help.
greeting
funkheld
Post by funkheld »
hello good day.
if change the A and B it ok:
create chra 255 c, 129 c, 129 c, 129 c, 129 c, 129 c, 129 c, 255 c,
create chrb 255 c, 12 c, 12 c, 12 c, 12 c, 12 c, 12 c, 255 c,
: chara
8 0 do i chra + c@ i 5128 + c! loop
8 0 do i chrb + c@ i 5136 + c! loop;
chara 5120 charbase! >>>>>>>>>> it ok !
this is not ok:
: charneu
2047 0 do i 32768 + c@ i 5120 + c! loop ;
charneu 5120 charbase! >>>>>>> it not ok !
not a single letter is changed.
greeting
Please download the latest D64 image, I've made a simple fix for the 0> bug.
This version of your code now works, it uses cmove rather than a loop
hex
create chrbyte ff c, 81 c, 81 c, 81 c, 81 c, 81 c, 81 c, ff c,
: charset
cd 9005 c!
8000 1400 800 cmove
chrbyte 1408 8 cmove ;
funkheld wrote: Thu Sep 12, 2019 1:00 am I started vforth.
Now I want to load an asm program "test.p" to $ a000
"load" test.p ", 8,1
how is that possible?
You'll need to define a word that calls the various KERNAL routines
: load
name count $setnam
1 8 8 $setlfs
0 $load ?ioerr drop ;
load test.p
funkheld
Post by funkheld »
Hello, good evening.
Thank you for your tireless help.
the vforth is a great thing for the vic20.
the command "charset" does not work.
I enter: charset 5120 charbase!
Thank you.
greeting
funkheld
Post by funkheld »
hello, this works
this is your demo, something shortened:
hex
: charset
2048 Char-byte to 5120 , asm starts with $a000:
!to "charsetasm.p", cbm
*=$a000
 charmem = $fb
 charmem1= $fd
  bloecke   = 8
start
  lda #$00
  sta charmem
  lda #$80
  sta charmem+1
 lda #$00
  sta charmem1
  lda #$14
  sta charmem1+1
  ldx #bloecke
  ldy #0
schleife
  lda (charmem),y
  sta (charmem1),y
  iny
  bne schleife
  inc charmem+1
  inc charmem1+1
  dex
  bne schleife
  rts
start with:
load "vforth.p",8,1
sys 8192
load charsetasm.p
sys 40960 >>>> a000
5120 charbase!
charset
everything ok.
Did you try my example with the latest disk image downloaded from https://eden.mose.org.uk/download/?
funkheld
Post by funkheld »
Hi good afternoon.
can you please explain the text exactly for the graphics and the mode?
Thank you.
greeting
104 80 bitmap mode gr
60 96 bitmap multi-colour or mode mg
160 160 bitmap double-height or mode dg
20 10 0 mode tx
funkheld wrote: Fri Sep 13, 2019 1:00 pm Hi good afternoon.
Thank you.
greeting
20 10 0 mode tx
The first two values are the maximum x and y values. The third is a set of mode bits to choose text vs bitmap, multicolour, double height.
Trying the examples something seems to be not working, it just hangs after clearing the screen.
I will try to spend some time this weekend re-writing the graphics subsystem to be simpler.
funkheld
Post by funkheld »
hello, thanks for overworking it.
will you get the fs out again?
Thank you for your many work.
i like this vforth especially because you have the
all vic20 so clean can address.
Thanks & Greetings
funkheld
Post by funkheld »
vforth.d64 2019-09-12 18:13 171K
the charset will not be rewritten here either.
only one letter is converted.
greeting.
funkheld
Post by funkheld »
Hi good afternoon.
I can not find a solution.
if "xb <0" xb should remain 0 , xb is then 21 , why ???
if "yb <0" yb should remain 0 , yb is then 22 , why ?
the key operation is:
for x: Q / E
for y: W / S
thanks
greeting
variable xb
variable yb
: cls
510 0 do 32 i 4096 + c! loop ;
: t81
if xb c@ 1 - xb c!  then  xb c@ 0  < if 0  xb c!  then ;
: t69
if xb c@ 1 + xb c!  then  xb c@ 21 > if 21 xb c!  then ;
: t87
if yb c@ 1 - yb c!  then  yb c@ 0  < if 0  yb c!  then ;
: t83
if yb c@ 1 + yb c!  then  yb c@ 22 > if 22 yb c!  then ;
: gehe
cls
10 yb c!  10 xb  c!
begin
	key
	dup 81 = t81
	dup 69 = t69
	dup 87 = t87
	    83 = t83
	." x= " xb c@ . ." y= " yb c@ . cr
	?terminal
until  ;
