3D Rotating Cube
DrVeryEvil
Occupation: Data Analyst
3D Rotating Cube
Post by DrVeryEvil »
SmallBitmap.zip
CBM Prg Studio project files
(1.58 KiB) Downloaded 97 times
Just something I pulled from C=Hacking and adapted to the VIC 20, using CBM Prg Studio. Try it out. If I can figure out how to attach the project files. LOL.
DrVeryEvil
Re: 3D Rotating Cube
Well the BBCode doesn't tell me how to attach a file and when I try to it says "invalid program extension". So I guess if you would like to check this out, email me and I'll send you the project files.
What type are you trying to attach? If you ZIP it up, it should work I think.
:shock: great to see in warp mode! (roughly 3600%, 170 fps, very fluid :)).
DrVeryEvil
That is cool, Mike. You must be a math wiz as well as a programming wiz. This is the kind of stuff that I find interesting and would like to learn more about. Can you tell me anything about your code?
Kakemoms
Post by Kakemoms »
Just came across this demo from 2004: http://www.pouet.net/prod.php?which=13716
