FS: clones of Cardco Cardbus 3S
I will soon be selling clones of the Cardco Cardbus 3 slot expander.
Price tag is 45$US per unit
Shipping is 10$ for the US, 11$ for the rest of the world.
You can preorder now.
Re: FS: clones of Cardco Cardbus 3S
Well... don't all rush at once... there's enough for everyone!
No doubt, this will be another excellent eslapion VIC product
I would be all over this if I didn't already have several different slot expanders (including a Cardco 3S). Surely there are other Denial members that aren't slot extender hoarders like I am
I'd love one.
Could I then use my 32k expansion (ordered from k3ys and eagerly awaited) with my Super Expander Cart or Buti Cart with extra 3k (I don't have an ordinary 3k ram cart) to give me a full 35k vic?
@Vicist
Yes. Disable BLK5 is one slot, insert your 32k expansion there
Disable BLK 1-2-3 in the slot where you insert your Super Expander.
The result: a Super Expander with 24k expansion. Really nice.
I'm sold. Put me down for one.
I PMd Eslapion about this and it turned out there wasn't enough interest for him to do a run for this item.
You could always buy the XPander-3 VIC from Jim Brain:
http://store.go4retro.com/non-functional-goodies/
I had a problem with the page, but I think he should still have some left. He said in a video he made a 100 of them and then realized they were not wide enough to fit carts. He says in the video the revised version was in the works and would be available early 2013. However this never happened. I finally gave up waiting, bought two of the wrong ones and had some friendly fella do the modifications to mine and let him keep the extra one. See here for pictures of the modded XPander. If you only want a 35K expansion it should be safe using this without the modifications. You will probably need to disable $a000-$bfff for the slot you want to put the Super Expander in, so it's ROM does not interfere with the RAM of the 32K expansion. And you will probably need to open the Super Expander and use only its board unless you want to re-solder all the switches on the XPander to the bottom.
Just found this on Ebay, looks like a good alternative. It's from Dorktronic, same guy who does the new 32K-RAM-expansions:
http://www.ebay.com/itm/331695039509
Eslapion, go ahead and put me down for one. Thanks.
Barney
Barney
Honestly, the demand for such a product seems very small.
Not saying its impossible...
