Bulk order of 4700uF capacitors?
Vic 20 Item Exchange
Is anyone in Europe interested in a collective order of ROE 4700uF 16V capacitors to fit in original VIC-20s? The price would be about £2 (2.75 €) plus postage (depending on total quantity ordered).
mrr19121970
Re: Bulk order of 4700uF capacitors?
Post by mrr19121970 »
Are these any good?
Fischer & Tauscher 4 @ 8.99 euro
Unicon 5 @ 7.00 euro
There's no specifications in the first, hard to tell.
The Unicon ones look to be rated to 85C, most recommendations I've seen for power supply capacitors recommend 105C and low ESR.
Commodore seemed to have used high quality capacitors, mine shows no sign of leaking so I'll wait until I can get hold of equally good replacements before I change it.
