"Ohne Dich": Play digital audio from tape in real-time
Website: http://hugbox.org/
Re: "Ohne Dich": Play digital audio from tape in real-time
Thanks to a most simple trick there's a quarter more bandwidth, stability of frequency and less distortions caused by low frequencies.
And there're no border effects anymore as they tend to ruin the sound on leaky circuitry.
Preview: http://hugbox.org/pixel/external/denial/ohne_dich4k.zip (4.4kHz)
Wanna bite myself in the back for this, because that trick's already been used trying to fix the video thing – which still does not work.
pixel wrote:
ral-clan wrote: TAPE TON works with the VIC-20. It's bad, yes, but not that bad. I recall it was good enough, in my testing, for me to play a 440Hz tone recorded on analogue cassette to help me calibrate the datasette motor speed.
I played around with audio recordings last night and didn't get anything usable out of it.
I'm not clear on whether or not you have an actual VIC-20, as in the beginning of this thread it seemed like you were asking people to try your program on real hardware (I assume because you don't have a real VIC-20).
Did you test TAP TONE on an actual VIC-20 and datasette? If so the only explanation I can give is perhaps you are using a PAL VIC? I"m using an NTSC one.
ral-clan wrote: Did you test TAP TONE on an actual VIC-20 and datasette? If so the only explanation I can give is perhaps you are using a PAL VIC? I"m using an NTSC one.
Nah. Did a small piece of code to check what's actually coming through from an audio recording and it wasn't much.
